anyone know alternators?
Old Nov 28, 2007 | 02:17 PM
mdacton's Avatar
Can I convert my stock 140 amp alt for my LT1 to a single wire? Install a self exciter?
If I can I would rather do that b/c I have the bracket/belts set up for it(madman/ATI stuff) If I convert it to a mini then I need pullies brackets etc. and set it up
Old Nov 28, 2007 | 07:22 PM
jasonisdn's Avatar
the place i get mine from was about to do it to mine. look in the phone book for a alternator/starter rebuild shop, they can do it for you. if you don't need a factory amp alternator look at the smaller alternators , for less weight
Old Nov 28, 2007 | 07:40 PM
mdacton's Avatar
I have a shop I use. I have to go pick up some stuff tommorow for some race cars so I will take it with me.
I would rather have a smaller one, but I will just use this one for now b/c everything is set-up for it and I'm running out of money
Old Nov 28, 2007 | 10:10 PM
mdenz3's Avatar
You should just be able to swap the regulator out. Why do you want to?
Old Nov 28, 2007 | 10:11 PM
mdacton's Avatar
cause I don't have the harness/plug for it......Its in a race car with DFI
Old Nov 28, 2007 | 10:13 PM
mdenz3's Avatar
So solder a wire to the middle small pin and run it to a switched power source.
Old Nov 28, 2007 | 10:16 PM
mdacton's Avatar
too much trouble
Old Nov 28, 2007 | 10:32 PM
mdenz3's Avatar
Originally Posted by mdacton
too much trouble
I geuss, but it's cheep and would only take 15 minutes. It beats finding someone who knows how to replace a regulator in an alternator, and IIRC the internal regulation regulators are pretty pricey.
Old Nov 28, 2007 | 10:37 PM
mdacton's Avatar
I got a guy that does them close by....he told me $35
he does those little ones for us.....but I don't think it will fit an LT1 b/c the water pump the bracket wont fit.
I will report back and see what he does
Old Nov 29, 2007 | 12:18 AM
CSJTA's Avatar
Running out of money, no way
Old Nov 29, 2007 | 11:14 AM
mdacton's Avatar
almost anyway
Old Nov 29, 2007 | 07:51 PM
mdacton's Avatar
$75 full rebuild new bearings etc and a self exciter so all I need is the power cable. Sounded good to me.....one less think to worry about at the moment
68camaroboltz
Oct 5, 2015 01:46 PM
drt
Sep 27, 2015 04:39 PM
tommalcolm
Sep 11, 2015 03:39 PM
Pwilson59
Sep 3, 2015 08:47 PM
Thirim
Jul 30, 2015 01:29 PM
