Anyone have the XE 227/233 cam?
Old Oct 5, 2003 | 11:00 AM
OffspringZ28's Avatar
If so, feedback? its relatively new and lifts really high. I have the XE224/230 but i might want to trade up for this one. Looks like its the perfect street cam.
227/233 duration, .560"/.569", 112lsa compared to my
224/230 duration, .536"/.544", 112lsa
what do you guys think?
Old Oct 5, 2003 | 01:35 PM
Z95m6's Avatar
i wouldn't swap cams for only 6 more degrees of duration. I would think about doing heads instead they will wake your car up.
Old Oct 5, 2003 | 01:38 PM
93ZM6Tally's Avatar
I have that cam on a 111 LSA. So far I like it. It seems to have moved my power band up a little and I haven't sacrificed any driveability, (I had a CC305). I don't have any new times or dyno numbers yet. I plan on hitting the track this coming weekend and will let you know.
Old Oct 5, 2003 | 01:59 PM
ledfootz28's Avatar
would that cam pass emissions
Old Oct 5, 2003 | 02:48 PM
Beast96Z's Avatar
Try 3 degrees! No way would I go through a cam swap for 3 degrees of duration. You might see 7-10 hp max. Guess it depends on if it is worth it for the little bit of power you would gain.
Old Oct 5, 2003 | 02:53 PM
Z95m6's Avatar
i said 6 because there is 3 on intake and 3 on exhaust.
Old Oct 6, 2003 | 04:58 PM
Its the lift numbers im looking at. Good bit over the 224/230 specs. think i could hit 350@the wheels with the XE224/230 and a good tune?
Old Oct 6, 2003 | 11:47 PM
Fastbird93's Avatar
I would venture to say that you could hit 350 on stock heads with the 227/233. Someone on here just pulled about 343 with the 218/224, but that's better suited towards stock heads also. The 227/233 should really shine with a good set of ported heads, but if you're going with that, why not just grab the 230/236 which is already proven?
Old Oct 7, 2003 | 03:11 AM
94 TA TT2S's Avatar
I would stick with your current cam....
Check Chris's site Out he has the exact same came 362/330 TQ ....(Chris...I hope you don't mind ) http://www.chris96ws6.com/
Old Oct 7, 2003 | 03:31 AM
Fastbird93's Avatar
NICE!!!!
Old Oct 14, 2003 | 09:08 AM
Fenster's Avatar
Chris is running the 224/230 and getting those #s...
i already told him that we are getting his car into the 11's at some point w/ that combo... just needs some real cool weather and a little diet... skinnies would help too...
i plan on running the 227/233 in the 355 i am working on right now. i would run the 230/236 but i have always been the bird of a different color... so i am gonna give the 227 a try!!
Old Oct 14, 2003 | 09:24 AM
Chris 96 WS6's Avatar
That 362 was at 13.6 Air/Fuel ratio, I haven't had a chance to hit the dyno again (well I did, but the opti was dying so it was a waste) but fattened up to 13.1 it should make 370.
Also the accurate Tq reading was 380, had to reflash the PCM to prevent a downshift at WOT so the dyno would get a good tach signal for the TQ reading.
I have an LTCC opti conversion waiting to go on and then I am gunning for 12.1s...maybe with some weight reduction 11.99s.
My 224/230 is on a 114LSA and driveability is great, I'm happy with the combination of power vs. street manners as I drive the car every day.
If I had known about the 227/233 at the time I probably would have gone with it but I was about 3 mos to early.
rideordie
Nov 5, 2019 04:52 PM
alex5366
Feb 17, 2015 08:12 PM
Queens94z28
Dec 20, 2014 09:11 PM
Queens94z28
Nov 20, 2014 06:03 PM
