anyone have a whine with the lt4 timing chain kit?
Old Nov 29, 2004 | 06:44 PM
ws6fromhell's Avatar
as soon as i started the car after cam install it had this whine noise when revved up. never there before. tried adjusting rockers, removing belt, replaced opti-spark, water pump. and checked for vacum leaks. no luck yet. gets higher pitched as rpm increases. pulled timing cover off, no signs of contact anywhere. am i chasing a problem that is normal with this kit? my coworkers tease me about having a supercharger its so loud. any ideas????
Old Nov 29, 2004 | 07:27 PM
dmoor88's Avatar
Re: anyone have a whine with the lt4 timing chain kit?
silly question, but did you line up the timing teeth correctly when you replaced everything? is the opti totally flush with the timing cover?
Old Dec 1, 2004 | 08:16 AM
yup, the opti is setting flush, both where. i actually removed the cover to check the teeth, positioning, tone wheel etc, visually i cant find a problem. but it whines like a byotch.
Old Dec 1, 2004 | 08:58 AM
Mikey97Z's Avatar
I had a whine like you describe. Unfortunately, my gear got ate up. I think it was caused by the water pump.
I posted a pic here in this thread.
http://web.camaross.com/forums/showp...4&postcount=26
Old Dec 1, 2004 | 05:45 PM
Sevendustx1's Avatar
Did you buy just the chain or the gears as well?
Old Dec 1, 2004 | 05:54 PM
Spinner's Avatar
Sounds like the gear/chain may be rubbing the cover a bit? That will cause a hell of a whine.
Old Dec 1, 2004 | 06:01 PM
ejfagala's Avatar
Did you repace the idler gear? my kit came with three gears not two and I have heard if you do not replace the one for the water pump idler gear it will tear up the cam timing gear.
Old Dec 1, 2004 | 10:22 PM
truedualws6's Avatar
I don't have a whine, but I do have a new sound at idle. It's hard to
explain because it's very subtle. Some kind of new engine noise that
is not the rockers or lifters. I just assumed it was the LT4 ED timing
set since that is the only change made that could make noise.
Old Dec 2, 2004 | 12:32 AM
T/A#4's Avatar
I saw an article awhile back about drilling some small .050 holes in the crank gear I belive to supply more oil to the chain to quite things down a bit. Moreperformanceinc.com has the setup & it's reasonable. Some where under $50?
Old Dec 2, 2004 | 04:07 AM
1racerdude's Avatar
There are small holes in the FACTORY oil galley plugs in the lifter oil galleys,behind the gear,that spray oil on the timing set.If they have not been replaced with ones with holes in them your timing set is gonna suffer.
Most shops don't notice and put in regular plugs from a non LT-1 and they have no holes,unless they are drilled. ooopppppppsss
WildRidez
Jan 16, 2015 03:10 PM
phoenix95
Jan 8, 2015 02:44 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
GigaMp3z
Feb 20, 2003 02:57 PM
