Anyone have the TPIS Longtubes with dual-cat y-pipe?
Old Oct 20, 2006 | 06:57 PM
Camarocracy's Avatar
I read an old post about them, and the one member that did have them seems to no longer be a member here. So does anyone have the TPIS longtubes with the dual-cat y-pipe?
If so, how was the install?
How's the ground clearance?
How's the plug access?
Did you use OVC plug wires?
Where are the cats located at on the y-pipe?
Any pictures?
Old Oct 20, 2006 | 07:20 PM
1 slo 6's Avatar
Re: Anyone have the TPIS Longtubes with dual-cat y-pipe?
i had installed some not to long ago and they fit way better than the other LT on the market.... that is y u r paying so much for them. he had a stock wires clearance was good on a sportlined dropped Trans Am and plug acces was way easier... you also dont have to beat in the bottom of the car like u do in some cases with other LT headers. it is a bitchin lookin header too i am thinking about some
Old Oct 20, 2006 | 08:22 PM
Clean97Z's Avatar
I have the TPIS long tubes minus the dual cat y-pipe. The ground clearance for the header is excellent, plug acess is great and an easy install. I had a custom ORY pipe built which helps maintain the great clearance. I can easily clear speed bumps and I'm lowered just over an inch. The cost was a up there but I think it was worth it.
G-BODYT56
Jan 14, 2022 11:14 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
tdigger9899
Sep 7, 2015 10:56 AM
97SSdude
Aug 21, 2015 09:36 AM
