Anyone have a pic of a labeled 96-97 engine harness?
Shoebox, ive been using your site, but there are a few plugs on the 96 harness that are not on the 95. Just wondered if anyone had the same kind of pic for a 96-97 A4 harness. Thanks.
The only difference is the additional connectors for two rear O2 sensors, the crank position sensor and the EVAP vacuum switch and the coil has a different connector. That's about all I can think of.
Yea I cant get it any clearer cuz im laying under the car taking the pic and thats as far away from it i can get. I have the car jacked up about 2.5 feet. Ill try again tonight when I get home. The pic you refrenced showed an o2 sensor , I have all 4 of those. so it cant be that. my Knock sensor is plugged in. How many wires go to the starter? I know that i have one. Im wondering if its the PCM ground and ingintion starter Solenoid leads?
This pic is bigger but its still blurry..
http://i27.photobucket.com/albums/c1...d/ac3e2e98.jpg
The square connector is what a rear O2 would use.
I got a clearer pic lastnight and I think ur right. The purple has to be the starter ignition lead and the black is the pcm ground. I was just thrown off because the rear O2 sensor was so close, I figured it would have been farther back.
That plug is for the driver side after cat o2
Re: Anyone have a pic of a labeled 96-97 engine harness?
I need a picture of that entire harness (1996 Camaro z28 V8 LT1 A4 Engine harness) with where the plugs go because i have a couple things missing off of my harness but are not triggering any codes. I also need to know where ground wires on the Coil Stud Post go to. Where do i buy a new harness if i needed to.
Jan 5, 2015 07:14 PM
