Anyone have a certain valve spring tool they use?
Old Nov 28, 2006 | 09:15 PM
MeanGreen97Z's Avatar
I wanna change the springs while the heads are still on the car. Anyone use one that can get under the cowl without needing much space?
Old Nov 28, 2006 | 09:18 PM
96capricemgr's Avatar
http://www.mytoolstore.com/kd/kdengi13.html#3271
I have one like the 3271, not the fastest tool to use but works well. Beehives small retainers add a little extra challenge to using it but still perfectly usable.
Old Nov 28, 2006 | 09:21 PM
This will be with lt4 springs.
Old Nov 28, 2006 | 09:26 PM
I like that 3271 style tool. I think I may go with that. Not bad for 39$ either.
Old Nov 28, 2006 | 10:45 PM
Skull Leader's Avatar
Exclamation
To change my springs & roller rockers, I used a bolt type tool from Lisle. Works good once you get the hooks in. I took the handle off and used a ratchet.
http://www.jcwhitney.com/webapp/wcs/...atalogId=10101
Old Nov 29, 2006 | 01:02 AM
Jazsun's Avatar
The crane valve spring tool will reduce the time needed to do a full spring swamp by at leaste an hour and its a **** load easier to use. Just attach a ratchet and bolt it up. http://thunderracing.com/catalog/?ac...id=171&sid=526
Its expensive but sooo good.
Old Nov 29, 2006 | 04:39 AM
kingman109's Avatar
i tried about 3 different ones, and when it came down to under the cowl, this was by far the most effective. Not easy, but it did the job- and did it better that the expensive ones-
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
nikolt1
Feb 27, 2015 09:10 PM
Red_94Formula
Jan 22, 2015 12:17 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
