anyone got pics of the ports on there ported heads?
Old Feb 10, 2004 | 09:31 PM
IrocSS85's Avatar
Im porting my own heads (Ive done this before, but not LT1 heads) and would just like to see what others have had success reshaping. flow #s to go w/pic would be nice too. any does and donts? paying to have them ported is not an option right now.
chris
Old Feb 10, 2004 | 10:36 PM
jasons93z's Avatar
Re: anyone got pics of the ports on there ported heads?
chris
Id be interested too
Old Feb 10, 2004 | 11:02 PM
TSAEB's Avatar
maybe this will help its a step by step instruction with pics http://www.sa-motorsports.com/diyport.htm
Old Feb 11, 2004 | 05:52 PM
IrocSS85's Avatar
well, Ive done this before, but that still had a few tidbits of info I didnt know. like the use of wd40 to keep the cartride rolls from loading up, and that the speed should be around 10K rpms. what I really wanted was to see some LT1 heads that have been done.
thanks though.
Old Feb 11, 2004 | 05:54 PM
JordonMusser's Avatar
West South Central Moderator / Special Guest
www.musserracing.com, link at the bottom
Old Feb 11, 2004 | 06:14 PM
Chopstix's Avatar
pics and flow #'s
http://www.cardomain.com/id/chopstix396
if you want any other info just give me a holla'
Old Feb 11, 2004 | 06:29 PM
IrocSS85's Avatar
Originally posted by Chopstix
pics and flow #'s
great pics and flow #s. are those heads decked to get that cc or what?
jordan, all I found on there was shifter cart pics. the link you put didnt work, so I used the one in your sig. looks to be the same one. any idea whats up w/dat?
thanks though to you both.
Old Feb 11, 2004 | 08:01 PM
KillWhitey's Avatar
http://www.musserracing.com/index.htm
Old Feb 11, 2004 | 08:02 PM
KillWhitey's Avatar
This should help you out
Old Feb 12, 2004 | 06:40 PM
Chopstix's Avatar
yes the heads were milled to acheive 11.5:1 w/stock short block
When building the stroker we ordered pistons to get the other .5
The heads are early (99ish GTP's)
they were flowed by Brodix
I am pleased with the performance and the car looks and sound very mild
I have even had almost stock LT1s wanting to race
Old Feb 12, 2004 | 07:26 PM
IrocSS85's Avatar
yeah, that was perfect. thanks
chopstix, thanks for the replies.
Old Feb 12, 2004 | 07:41 PM
TriPinTaZ's Avatar
www.tripintaz.com
click on picture gallery, you will see pics there
Old Feb 12, 2004 | 08:30 PM
IrocSS85's Avatar
cool website, fin. the mods page. well, how did those heads flow? also I noticed that you removed the exh. valve guides completly from the exh. ports, Ive never seen this done before. doesnt that give you any problems w/valve wear/rockin in the remainder of the guide? removing that thing prolly added tons of flow. what size are those valves? look too big to be stock. I might replace the stock valves w/some back cut ones of the same size. gonna look into how much. if its not too much, it would add some flow too. but if exp., then Id just wait till I can buy some better heads that already have bigger valves.
Old Feb 18, 2004 | 07:15 PM
TriPinTaZ's Avatar
Heads were done by www.theengineworks.com
There was a ton of work done to them, not only porting a polishing but the cumbustion chambers were reshaped and polished, the valves were unshrouded as well. Valves are 2.00/1.60 fer. race valves.
sorry the site is temporarily under improvments so pics are not avail. for a few days until i finish the new site
oldschool
Feb 9, 2016 09:21 PM
Roadie
Feb 16, 2015 10:34 AM
LT14LIFE
Feb 9, 2015 09:35 PM
MadMav
Feb 6, 2015 11:02 PM
