anyone ever used a DIY AC recharge kit?
Old Jun 11, 2003 | 12:24 PM
blak96SS's Avatar
I saw them @ Autozone, but was hesitant to buy it. A friend of mine used one on his BMW, and it worked well at first but I dont know how long it lasted. Anyone ever used one? Is it worth the $30 or so, or should I just take it somewhere??
Old Jun 11, 2003 | 12:36 PM
Sam95ZNoTop's Avatar
Re: anyone ever used a DIY AC recharge kit?
First, make sure your car has R134a in it, if it's for your 96, it will be, there's a sticker under the hood that tells you.
Second, it will only help you if the system is not leaking, otherwise the new R134a will leak out pretty quickly and you'll be back where you were in no time.
You can try to recharge it one time with a DIY kit, it's pretty easy, make sure you get one with a gauge so you can read the pressure. Both too low and too high a pressure will result in poor cooling. Add only on the low (suction side) of the system with the compressor running (engine on and A/C on max)! If the compressor does not stay running, disconnect the connector to the pressure switch and put a paperclip in the connector to get the compressor to run. If it cools good for a while and then stops working again and the pressure is down again, you have a leak and you should probably take it somewhere to get tested/fixed.
HTH
Sam
Old Jun 11, 2003 | 12:42 PM
blak96SS's Avatar
it shouldnt be leaking at all..It worked fine until I pulled the condenser out when I changed the radiator. I lost all the freon then and just havent done anything about it yet. Thanks!
Old Jun 11, 2003 | 12:57 PM
JohnD's Avatar
If you let all the pressure off and air in, you will need to pump it down with a vacuum pump first. It's always a good idea to change out the dryer bag in this case too.
Old Jun 11, 2003 | 01:11 PM
blak96SS's Avatar
what is the "low service side"? Is it the metal hose with the connection on it that is right by the radiator? Want to make sure I do this right...
Old Jun 11, 2003 | 01:15 PM
madwolf's Avatar
Haven't used it on my Z, but I've used the retrofit kit on one of my beaters which had the older system and man, it worked great. Can't find a better deal at what it costs too!
Old Jun 11, 2003 | 01:30 PM
PGR's Avatar
PGR
If you've pulled the condenser and opened up the system, you'll need to attach a vaccuum pump and purge the system of air you introduced.
The air has moisture in it, and if you simply recharge the system, the moisture will freeze into ice crystals that will plug the expansion valve.
Attaching the vaccuum pump will remove most of the air, and allow the moisture to boil off.
You might be able to rent a vaccuum pump, but at this point it's probably cheaper to let a professional do it right.
Old Jun 11, 2003 | 01:34 PM
blak96SS's Avatar
oh ok. I didnt know that. I have been running the AC anyway (even though its not cold) since its been so hot here lately, so I didnt think there would be a problem. Thanks for the advice...
Old Jun 12, 2003 | 11:52 AM
PGR is right about needing to evacuate the system, I thought it was simply low on freon. He's also right when he says you're probably better off letting a shop do it, it shouldn't cost very much and you'll be sure that it was evacuated as best as possible.
Old Jun 12, 2003 | 05:15 PM
PGR's Avatar
PGR
The best way to do this is to attach a vaccuum pump overnight. Or at least, have the shop attach it in the morning, so it has a few hours to boil off the moisture, then charge the system later in the day.
lt1xondeck
Mar 18, 2016 07:22 PM
95z28man7
N2O Tech
Aug 16, 2015 10:58 AM
malikot02SS
Aug 15, 2015 01:11 PM
CARiD
Jul 7, 2015 08:19 AM
