Anyone ever done an opti on here before?
Old Nov 11, 2004 | 08:21 PM
SLPZ28Cmr's Avatar
I am doing the optispark ok my 94 LT1 Camaro tomorrow with a friend and I was wondering to see if anyone has done it and how hard is it to do it?
Old Nov 11, 2004 | 08:23 PM
ibanez6rg's Avatar
Re: Anyone ever done an opti on here before?
Should take a little less than an hour if you know what you're doing. Be careful with the coolant when you take the w/p off and stuff. Not difficult at all.
Old Nov 11, 2004 | 08:37 PM
Z95m6's Avatar
If your car is stripped down like some of ours, minus the AIR system it can be done in a little over an hour. If its your first time realistically look at a spending a few hrs on the project.
Old Nov 11, 2004 | 08:55 PM
Fuels94TA's Avatar
It's going to take longer then a hour to do. Here is a page to help you out. http://www.houston-f-body.org/tech/optispark/
Old Nov 11, 2004 | 09:00 PM
Bryan Smith's Avatar
Took me about 2 hrs my first time, but I was putting my CS"R" waterpump in at the same time.
Old Nov 11, 2004 | 09:23 PM
SLPZ28Cmr's Avatar
Sweet Guys thanks for all the info
Old Nov 11, 2004 | 10:34 PM
atljar's Avatar
Ditto. Without the AIR pump and a few other things in the way like most of the modded cars,an hour is possible with air tools.
If its your first time and car is pretty much stock, you will spend 2-4 hours. Dont forget new h20 pump gaskets.
Old Nov 11, 2004 | 10:38 PM
indieaz's Avatar
yes, first time it took me like 3 horus, second time like 2...now even witht he air pump there it takes me liek 90 minutes. AIR pump is only a couple bolts, but it sorta gets int he way. The real PITA is draining coolant and removing the water pump.
Old Nov 13, 2004 | 05:22 PM
pearlpurple's Avatar
another excellant reference guide to add to my stash, thanks!!
Formula Steve
Sep 19, 2023 08:31 AM
94Maroz28
Oct 27, 2015 04:38 PM
Ks0209
Oct 1, 2015 07:32 AM
colts0455
Sep 27, 2015 01:07 PM
jayblev95
Sep 26, 2015 09:44 PM
