Anyone ever burn an O2 wire on header?
Old Aug 22, 2005 | 11:07 AM
wlz28's Avatar
I think I may have and I was wondering what your cars acted like when this happened.
Mine randomly runs like crap ( Backfiring surging erratic idle) but when I unplugged the O2 it seemed to do better and steadied out the idle.
Old Aug 22, 2005 | 11:15 AM
2000GTP's Avatar
Re: Anyone ever burn an O2 wire on header?
Did you check the wire yet for any physical damage?
Old Aug 22, 2005 | 11:22 AM
wlz28's Avatar
yea. I guess putting it like " I think I may have" isn't the way to put it. It melted the harness BAD! It was pinned between the header and the inner fender well on the driver side.
Old Aug 22, 2005 | 11:34 AM
2000GTP's Avatar
Well if the harness is melted that bad, then I'm sure that could explain your array of driveablility problems. By unplugging the O2 sensor, I believe you are forcing the PCM to revert to its set open loop tables which would explain the better idle. Definitely repair the harness and use some cable ties to route it away from the headers.
25th_Trans's Avatar
I burned the plug from the computer connecting to the extension, melted together. It's been like this for almost a year, lazyness. If you wait for you engine light to come on the car will run fine, if you don't it will start doing what you were talking about. Mine does the same thing if I don't wait for the engine light, takes about 5 min after startup for it to come on. Shouldn't hurt horsepower really, my numbers are with the burnt wires.
Old Aug 22, 2005 | 05:26 PM
wlz28's Avatar
I took it for a short drive today ( with O2's plugged in) and right away it started surging and backfiring. It kept dying and eventually stalled and would not fire again until I let it sit for about 10-15 min with the O2 unplugged. And it idled steady at 1400 rpm. Does this sound like a burnt O2 wire also? I just had the motor installed right at 100 miles ago. So I figured there would be a few bugs, I'm just not sure if I've only got one to chase or maybe more.
Old Aug 22, 2005 | 05:32 PM
ZMAN Z28's Avatar
Just get a new connector and splice it in. Pay attention to where the wires go. Only splice one wire at a time. You may have also melted the ground wire that goes to the block also (if its passenger side).
ZMAN
Old Aug 22, 2005 | 06:54 PM
TUFF LT1's Avatar
I wouldn't ever splice an O2 wire unless it was on an 87 ford ranger! But, that's just me.
Old Aug 22, 2005 | 07:17 PM
ZMAN Z28's Avatar
The connector is melted, so how do you replace it. He is not talking about the wires on the o2 itself, but the electrical connector on the harness. I agree you are not supose to splice the o2 wires to make them extended or if it gets damaged.
So if the wiring harness wire that goes into the connector gets melted or damaged, then how do you fix that? Buy a brand new wiring harness. That makes no sense.
My wiring harness wires that go to the o2's, knock sensor and the ground that goes to the block all got melted together. I spliced in a new o2 connector, and repaired the knock sensor and ground wires. No issues what so ever.
ZMAN
Old Aug 22, 2005 | 07:57 PM
TUFF LT1's Avatar
OK, if it is the connector thanI wouldn't just toss a splice on there, I would solder it to a new connector. Good job fixing your problem zman!
http://web.camaross.com/forums/showt...ht=wire+solder
Good Luck wlz28
Old Aug 22, 2005 | 08:23 PM
jchevy's Avatar
When i burned one of the downstream o2 sensor wires on my car it popped the eng. sens. fuse in the fuse block under the hood. might want to give that a quick check.
grabbem88
Mar 18, 2015 01:25 PM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
blac94Z
Jan 12, 2015 05:44 PM
Jul 4, 2005 05:00 PM
