Anyone else using ACCEL injectors?
Old Aug 10, 2003 | 08:16 PM
12SCNDZ's Avatar
I put a set of 30# Accel injectors in my '93 Z when I did my head/cam/kitchen sink swap. It runs extremely rich at idle, and dumps black smoke on a run.
I'm running 36 # of fuel pressure presently.
I've been told by the person that burned my chip (PCMFORLESS) that Accel has had alot of problems with their injectors. Has anyone else had problems with them?
Frank
Old Aug 10, 2003 | 08:27 PM
J's 82's Avatar
I am using the Accel 24#s with 45 psi at idle.. no problems here.. I heard about the bad rep but decided to try them myself.. work fine
Old Aug 10, 2003 | 10:34 PM
zjet's Avatar
i have the old style they used to do they work great.i heard the new stlye(yellow top) dont work as well.i love mine the hp jumped 10 at the wheels.my stock ones must have been junk.
i am going with msd in my new motor 408 hope to dyno this week.
Old Aug 10, 2003 | 10:44 PM
J's 82's Avatar
I have the yellow ones.. though I did what someone on another board recommended.. remove the o-rings and xacto off any plastic casting flash.. there was a little.. Other than that no worries as of 7k miles.. guess we'll see..
Old Aug 10, 2003 | 10:45 PM
elista's Avatar
i run the 24#ers in my car with the yellow top at 36#s of pressure from an aeromotive works great , car runs a lot better all around,
Old Aug 10, 2003 | 11:17 PM
InjectedSS's Avatar
running the accel 30#'s here and there was no way those things ran right until i tuned them! you need to change your injector offset and raise your injector flow rate to about 34 as to lean it out!
Old Aug 11, 2003 | 06:58 AM
94LT1355's Avatar
What did you change your offset #'s to?
Old Aug 11, 2003 | 05:00 PM
12SCNDZ's Avatar
Um...This is a '93. I have a replaceable chip. It was SUPPOSED to be burnt for the 30# injectors by PCMFORLESS. The person who burnt the chip swears it's not in his tune. He blames it all on the Accel injectors. Can you supply me with any info that I can go back to him with?
Frank
Old Aug 11, 2003 | 05:29 PM
InjectedSS's Avatar
Frank
whoops sorry dude!
another reason why i always rip on 93's
Old Aug 11, 2003 | 07:54 PM
12SCNDZ's Avatar
Hmmm. Rip on '93's, you say? Did I mention mine went 12.82 @ 105.9 MPH BEFORE I ever touched the engine? 94,000 miles and never had the valvecovers off...With exhaust manifolds. Check out the January '03 issue of GM HIGH TECH PERFORMANCE. I ranked 9th in the country in their "Bolt-On" shootout last year. That was with a Generic Hypertech chip in my non-programable computer...LOL
'93's may be a little harder to get right, but once they're right, they're hard to catch.
Frank
Old Aug 11, 2003 | 11:22 PM
Dan K's Avatar
Frank
Is your 36psi of fuel pressure with the vacuum line off?
Is that what it was supposed to be set at per the chip burner?
Are you sure the state of tune on the car is up to snuff? O2's? Plugs, wires?
It's kind of hard to go back to the guy who did your programming and tell him that it's all his fault. Just make sure it's not something you're overlooking.
After that you should find a way to have your ve tables tuned. I've worked near miracles on a couple of 93's just by screwing with the ve tables for idle and part throttle.
Old Aug 12, 2003 | 05:02 PM
12SCNDZ's Avatar
New MSD 8.5MM wires, New Splitfire plugs, New TPS sensor, and New Optispark. No, I didn't replace the O2 sensors. I've checked them with my Snap-On scanner, and they're both about even @ 447 and 451 (cold, at idle-open loop) Freeze frame @ 788 and 863 (188 degrees, at 5000 RPMs- closed loop)
The 36# is with the vacuum hose connected. It's around 40-41 with it off.
Other readings are (at idle, open loop, 141 degrees):
left BLM: 122
right BLM: 122
A/F learned: No
Ft Cell: 16
Inj 1 fault: No
Inj 2 fault: No
TPS: .30
Throttle % 0
left BPW: 4.7
right BPW: 4.8
Lo Res. Signal: 23.3
IAC Pos.: 160
IAC Direction: FWD
Learned IAC 32
MAT 121 degrees
MAP (KPA): 55
MAP: 2.48 Volts
Knock: No
Retard: No
(5000 RPM, closed loop, 188 degrees)
left BLM: 128
right BLM: 128
A/F learned: No
Ft Cell: 15
Inj. 1 fault: No
Inj. 2 fault: No
TPS: 4.58
Throttle: 100%
left BPW 14.4
right BPW: 14.5
IAC pos.: 160
IAC direction: FWD
Learned IAC: 32
MAT: 114 degrees
MAP (KPA): 102
MAP 4.96 Volts
Knock: No
Timing: 36 degrees
(6200 RPM, closed loop, 188 degrees- 1-2 shift)
Timing 34 degrees
Retard: 4 degrees
Knock: No
IAC Direction: Rev.
throttle: 100%
MPH: 49
Frank
Old Aug 12, 2003 | 07:54 PM
INTMD8's Avatar
From: I reached back like a pimp and smacked that LS1....
Accel injectors are junk. I've seen them mismarked on more than one occasion.
One set of 24's were marked 36's.
Ed Wright has had the same problems with Accels also.
Old Aug 12, 2003 | 07:58 PM
93.FORMULA.WS6's Avatar
I had the same problem with #30 accel injectors, I had the chip burned, for them but it never ran right it would load up, rin really rich, I was having to change plugs all the time. I called ed wright and they explained to me that accel injectors were High impedance, and on the '93 they can only burn a tune with low impedance injectors. He suggested I switch to a low impedance injector like the SVO #30 red top injectors. Car runs like a top now!
just a thought.
Old Aug 12, 2003 | 08:28 PM
rage366's Avatar
man! the ppl in this post sure do have a lot of lines on their sigs.
i'm actually planning on getting the yellow accel 30's. hmmm...not sure yet.
