Anyone else have these leaks??
I noticed that I have a "slow" leak at both ends of the drive shaft. There is tranny fluid on the torque arm bushing at the front of the driveshaft, and some fluid on the rear of the torque arm(where it atttaches to the differential). The fluid is not dripping or anything like that, but its very fresh cause you can see the redness of the fluid very clearly on the torque arm. Is this normal? My car is 9 years old with 69,000 miles and im thinking there are some seals that may need to be replaced.
ps. I do have the famous in-balanced drive shaft on my camaro, it usually kicks in around 112mph. I wonder if that has aggrevated the situation.
Re: Anyone else have these leaks??
yup i had those same leaks got it fixed about a week ago bit i never felt any vibrations soo im not sure hoe that could have happened to me,.....but they are fixed now and im happy....
rear pinion seal and transmission tailshaft seal
