Anyone with 383 and 236/242 cam
Just curious if anyone has a similar setup and run into piston to valve clearance issues with this setup.
383
5.7 rod
236/242 cam
1.6 rockers
flat top pistons
383
5.7 rod
236/242 cam
1.6 rockers
flat top pistons
You obviously need to just check it, regardless. However, most don't have issues with stock shortblocks, and whatever aftermarket piston you has probably has larger reliefs than stockes anyhow. I doubt you'll have issues.. but never the less, check it, every time
