Anyone with 383 and 236/242 cam
Old Nov 20, 2003 | 06:05 PM
wicked_95z's Avatar
Just curious if anyone has a similar setup and run into piston to valve clearance issues with this setup.
383
5.7 rod
236/242 cam
1.6 rockers
flat top pistons
Old Nov 20, 2003 | 06:46 PM
Ai's Avatar
Ai
You obviously need to just check it, regardless. However, most don't have issues with stock shortblocks, and whatever aftermarket piston you has probably has larger reliefs than stockes anyhow. I doubt you'll have issues.. but never the less, check it, every time .
Old Nov 20, 2003 | 07:59 PM
Kyle@CSS's Avatar
242/248 540/563 on a 110. no problems here. flat top je pistons. and angled mill heads. but do check.
drptop70ss
Mar 26, 2015 01:50 AM
transam_388
Mar 15, 2015 11:53 AM
Killer94z
Jan 13, 2015 12:06 PM
Queens94z28
Nov 20, 2014 06:03 PM
