Anybody use Sea Foam Deep Creep?
Old Dec 28, 2003 | 06:17 PM
WhiteThunderZ28's Avatar
Question Anybody use Sea Foam Deep Creep?
Anybody use the SEA FOAM DEEP CREEP?
And what are the results you got?
Old Dec 28, 2003 | 08:31 PM
slopokrodrigez's Avatar
Waste of time and I sell the stuff. Didn't do a thing for mine. Just think about a few things before you use it. If it removes the stuff they say it does and you have cats, what's gona happen to the cat(s)? What would it do to marginal (old) O2s?
Just my .02
Old Dec 28, 2003 | 10:03 PM
wrencher's Avatar
The deep creep rust buster right???
It's ok like PB blaster IMO.
Old Dec 29, 2003 | 01:59 AM
ThirdGenLT1's Avatar
Works good as a general lubricant. I use it when I store my car. Take vac line off brake booster and spray into vaccum line. It smoked like crazy when I started it 6 months later, so it did it's job of coating the cyl walls with lube so they won't rust. I think normal motor oil will do the same thing, as far as preventing rust on the cyl walls. Decent product if you ask me!
Matt
Old Dec 29, 2003 | 09:44 AM
scoobysnax83's Avatar
Great stuff, I like it. You can accompolish the same thing with carb/*Throttle Body cleaner*. But I think Deep Creep works best when the TB is hot, which is also when carbon is easiest to get off.
(*Edit) Sorry, my head was lodged where it shouldn't be.
Old Dec 29, 2003 | 10:46 AM
Red96Lt1's Avatar
If you're just wanting to throw it in the engine, just get the regular seafoam, non aerosol. It's a few $ cheaper, and take a line off the TB and pour it down there.
Old Dec 29, 2003 | 01:58 PM
BigRich's Avatar
i think shooting my throttle body out with Deep Creep when it was hot really smoothed out my low end. i saw little bits of black stuff coming out in the deep creep near the opening
2QUIK6
Sep 17, 2016 02:31 PM
PopoFormula
Oct 12, 2015 04:19 PM
95craz28
11
Sep 12, 2015 07:47 AM
mlopezart
Sep 8, 2015 12:15 PM
WPHIG2
Aug 27, 2015 06:37 AM
