anybody sell adj. timing chains for LT1/LT4?
Old Feb 14, 2007 | 10:04 PM
  #16
Z95m6's Avatar
Originally Posted by quarterboy
how do you plug the hole
I wouldn't weld it shut. Just get a freeze plug as its quick and easy.
Old Feb 15, 2007 | 06:19 AM
  #17
quickSS's Avatar
Make sure you DO NOT get just any gen 1 timing set. You need a timing set for "factory roller cam"
If you don't want to spend more than $10 or $20 bucks just keep the stock timing set up and buy a cam pin bushing kit. They work very well. If you find that your cam is not in phase with the crank as per cam card you can correct it with the cam pin offset bushing and also that brings the optispark back to dead-nut-on perfect. Most machine shops can drill the oversized hole in the cam sprocket for the bushing kit.
Oh, and RTV a quarter or better yet a 50-cent piece to the water pump drive shaft hole.
Karl
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
GigaMp3z
Feb 20, 2003 02:57 PM
