Anybody running 1.6 NSA rockers with guideplates under stock valve covers?
Old Mar 31, 2004 | 11:47 AM
T/A lt1's Avatar
I am thinking about selling my LT4 SA rockers to upgrade to Promagnums NSA with 7/16 studs and guideplates but don't know if they will fit under my stock valvecovers. Anybody try this yet? LMK Later Clint.
Old Mar 31, 2004 | 11:50 AM
Naegash's Avatar
Yes, you can do it (I'm doing it right now). The only thing you need to do to modify your stock valve covers is use a pair of needle nose pliers to flatten out the folds in the arches on the underside of the cover. Sounds a little confusing on paper, but just take a look under your covers and you'll know exactly what I'm talking about.
Old Mar 31, 2004 | 12:03 PM
Valkyn71's Avatar
I couldnt get the supports to line up after bending the bottem part down, so i took a recipracating saw and hacked them out...no problems so far.
Old Mar 31, 2004 | 12:22 PM
JasonK94Z's Avatar
I'm doing it with Crane Energizers. No fitment problems at all.
Old Mar 31, 2004 | 12:25 PM
T/A lt1's Avatar
Cool I'll be doing that too. Later Clint
Old Mar 31, 2004 | 12:36 PM
T/A lt1's Avatar
What guideplates are you guys using for the 7/16 studs?
Old Mar 31, 2004 | 12:39 PM
Shon Herron's Avatar
I have the stock VCs, I cut out the support and grinded on the other side. I dont recall which support I took out but one of them.
My GPs are stepped so I had to remove the support for them to work right.
Old Mar 31, 2004 | 01:27 PM
All_Z_Way's Avatar
Yes I am running nsa's with the supports cut.
Old Apr 1, 2004 | 01:03 PM
SVT Killer LV's Avatar
It doesn't matter what guideplates you use as far as fitment goes....
IMHO The ONLY two to use are
GMPP or the ISKY's
Old Apr 1, 2004 | 01:14 PM
T/A lt1's Avatar
Cool I hope the Comps I bought fit OK. I will know tommorow.
Old Apr 1, 2004 | 01:16 PM
WS Sick's Avatar
I'm running comp pro mags and guideplates. I had to clearance the back (closest to intake) brace inside the VC.
Old Apr 1, 2004 | 02:20 PM
llafro's Avatar
I am running the Comp Pro Magnum rockers, 7/16 stud, and guideplates. No problems here. I am using Comp's guideplates.
BRAD
HectorM52
Jul 30, 2017 11:46 AM
alliance12364
Mar 6, 2015 04:39 PM
Jazsun
Dec 29, 2014 12:14 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
