Anybody port there own intakes? TIPS?
Old Mar 2, 2006 | 07:59 PM
mattbailey's Avatar
I bought a set of ported heads, but I want to port my intake also. Any tips on how to port, key areas? Any tips appreciated.
Old Mar 2, 2006 | 09:27 PM
FastZinTennessee's Avatar
Re: Anybody port there own intakes? TIPS?
I worked on mine a bit. It was actually quite a bit easier than doing the heads. I layed the gasket on the manifold sealing surface and lined up the bolt holes as best I could to get the gasket position as close as possible. From there I just did a simple gasket match on the runners, and tried to keep them the same size for the whole length.
After this I started in behind where the throttle body goes, and tried to flatten or smooth out some of the parts of the casting that protrudes too far into where I thought the airflow coming from the TB might be.
You could also go ahead and open the throttle body bores on the intake to accept a 58mm TB later on, just in case.
Drtryder
Apr 22, 2015 04:17 PM
alex5366
Feb 17, 2015 08:12 PM
MadMav
Feb 6, 2015 11:02 PM
BLUETOPTA
30
Sep 18, 2002 12:22 AM
Teal94V-6
Aug 31, 2002 09:21 PM
