Anybody got a clue to why my car is running very very rich (datalog inside)..
Re: Anybody got a clue to why my car is running very very rich (datalog inside)..
Originally Posted by Sweetred95ta
I had a problem with my MAP being too high and in that part of the timing table, it was pretty advanced. It makes the car run richer too, but it shouldn't run that rich. The timing and MAP I see, with a good tune, shouldn't make your car flood itself out.
It's hard to say from those tables, but I would say that the tune probably isn't the problem. If your timing was too advanced, you would be getting knock retard. You're not getting any of that. Maybe the computer is bad? I wish I could help more.
If the ignition timing is to late/advanced that could cause the excess loss of vacuum as well, right? Right now I’m really stumped to why it won't make more vacuum than this, it doesn't make too much sense... the only thing I haven't been able to do is to go around and spray everything with carb cleaner to check for intake leaks that way, because it won't idle, but all the hoses are hooked up and or blocked off and there it so much RTV on the intake manifold that it is hard to believe that it could possibly be leaking at the intake.
I was told that adding timing would increase vacuum, but that was also supposed to be accompanied by leaning it out too. I tried it and it didn't work for me though. I ended up having to take timing out because it was spark knocking. I have a vacuum issue too. Mine is pulling like 9" Hg at idle. My cam is a little bigger than yours, but when I give it gas, it builds the vacuum up where it is supposed to be. I don't remember (I'm at work) but I think your car was building alright vacuum at higher rpm's. I didn't know the 93' cars didn't have replaceable KM's. You should pull the injector fuse and try to run the car on starting fluid. Have someone help you and see if the car will run at all with starting fluid. Freescan won't work on your car. I didn't notice earlier, but you have a 93 and it is setup to work with 94-95. I'm stumped.
Just fyi, I found this post that Gripenfelter made showing how to desensitize the stock KS.
http://web.camaross.com/forums/showthread.php?t=458177
Originally Posted by Gripenfelter
What mods do you have that require you to run 42# injectors?
Little confused on the second part of your reply... what is the purpose of running the starting fluid?... (It does run without flooding out with the stock 22# injectors, just very very very rich. The flooding problem is definetly a issue with the 42# injectors tho.)
You were asking about the timing and if it would run smoothly for a few seconds on the starting fluid, then you would know if the everything else is working correctly. Then, you would need to just focus on the fuel issue.
What are your MAP readings at idle? What is your idle? Aftermarket cam? My work's firewall won't let me DL your csv file.
Check your fuel pressure regulator and see if you smell fuel out of the vacuum line as well.
The car doesn't idle by itself at all (you'll see) so I have to keep tapping the gas to keep it running. It is suppose to idle at 900 rpms, and around that rpm it appears to in the range of 22" hg MAP with the barometric pressure being at 29.54" hg.
The cam specs are 224/224 .573/.566 (1.6 rockers) with a 108 LSA. The fuel pressure sits at 39 PSI at the Shrader valve with the vacuum line attached.... Check out my first post it has most of the stuff I have already checked. I'll pull off the vacuum line to make sure there's no fuel in it in a bit.
I just saw your email, i'll email you that file in a couple seconds.
squarehead
Nov 21, 2014 08:02 PM
