any1 know much about loading a program onto ur pcm?
Old Nov 8, 2004 | 06:33 PM
glennxx1's Avatar
i got a cable and tuner cats, ..i treads diagnostics fine with teh free progs they sent, but will NOT upload program, it just sits on "establishing communications" the whole time..never advances have the ignition on key off...stumped
Old Nov 8, 2004 | 06:51 PM
Z95m6's Avatar
Re: any1 know much about loading a program onto ur pcm?
you have the key in the on position?
Old Nov 8, 2004 | 06:57 PM
PatriotTA's Avatar
Before you try to upload a program, its good practice to download the program first. Not only is it good to keep an un-molested copy of your tune, you can't mess up your PCM by downloading. You can however, mess things up during a failed upload. Make sure the key is in the "run" position and you have the correct COM port selected in Tunercat, as well as the correct PCM definition file. Once you can download a file, you should be able to upload one.
Old Nov 8, 2004 | 07:23 PM
glennxx1's Avatar
key is in the on position, and i cant get it to establish communications at all, downloading or uploading, but it will read diagnostics.....
Old Nov 8, 2004 | 09:02 PM
TQdrivenws6's Avatar
Is the infrared port disabled on your computer? That gave me tons of troubles.
Old Nov 8, 2004 | 09:31 PM
glennxx1's Avatar
infared port disabler? what is that? (i have wireless internet ...possibly? how would i de activate it
Old Nov 8, 2004 | 11:28 PM
turbo_Z's Avatar
Try searching in the computer/diagnostics section and you might find some leads.
You could try the DOS version of the flash/read programs. Its safer IMO than windows b/c DOS is so simple and no other programs run at the same time. Tunercat will send them if you ask but you need a special boot disk with XP as it doesnt have DOS... just PM me if you need that. Hope that helps.
Old Nov 15, 2004 | 08:29 PM
wwarnke's Avatar
are you trying to run Datamaster and Tunercat at the same time?
Only one program can be using your COM port at a time.
Aug 24, 2015 06:41 AM
88IROC_Z
Jul 22, 2015 11:38 PM
whitehooptie
Jul 22, 2015 10:25 PM
Bz8
Jul 13, 2015 04:46 PM
asilomar244
Jul 12, 2015 05:53 AM
