Any tips for removing frozen crank pulley?
well the thread title pretty much says it, can anyone offer any tips on how to get my crank pulley off it's stuck to the hub pretty badly, and i need to remove it in order to install my new opti
Get a gear puller ( looks like a 3 fingered claw with a threaded rod in the middle) and grab the middle of the pulley and it should come off eventually. Spray it with some WD-40 or something 1st though to help it slide off.
thanks so much for that picture shoebox, helped me a ton, do you think i can borrow a puller like that from autozone or discount autoparts? i priced one at sears and it was almost 200 dollars
