Any tips for removing frozen crank pulley?
Old May 14, 2004 | 09:13 PM
HunterLT1's Avatar
well the thread title pretty much says it, can anyone offer any tips on how to get my crank pulley off it's stuck to the hub pretty badly, and i need to remove it in order to install my new opti
Old May 14, 2004 | 09:17 PM
Mizz96Z28's Avatar
Get a gear puller ( looks like a 3 fingered claw with a threaded rod in the middle) and grab the middle of the pulley and it should come off eventually. Spray it with some WD-40 or something 1st though to help it slide off.
Old May 14, 2004 | 09:32 PM
Spinner's Avatar
What he said. But it's easiest to remove the pulley and hub as one
Old May 14, 2004 | 10:18 PM
A properly attached puller will get it off. You don't need to remove the hub to get the opti off.
Old May 14, 2004 | 10:47 PM
HunterLT1's Avatar
thanks so much for that picture shoebox, helped me a ton, do you think i can borrow a puller like that from autozone or discount autoparts? i priced one at sears and it was almost 200 dollars
Old May 14, 2004 | 11:04 PM
You might be able to rent one. Someone said AZ had that very puller. I bought the one in the pic from Advance Auto for ~$25 or somthing (can't remember exactly).
Old Sep 16, 2004 | 01:29 PM
Jeffs94Z28's Avatar
Re: Any tips for removing frozen crank pulley?
hey i got the pulley off thanks to a great picture soebox took for using the puller. Thanks alot man.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Rde Bandit
Mar 21, 2015 10:17 PM
SpeedJunkee
Jan 27, 2015 10:02 PM
