Any Suggestions to Fix High Rpm Miss??
Old Aug 2, 2003 | 10:23 PM
Brandon 95 Z28's Avatar
Red face Any Suggestions to Fix High Rpm Miss??
I have a bad high rpm miss over 4800 rpms's the car starts to sputter and backfire really bad until i shift gears. The opti, plus, wires, and coil are all less than a year old. I was wondering if new o2's or if it could be fuel related, and where i should start looking Nothing appears to be arcing. Any help or advice is appreciated, I want to finally be able to go to the track again soon
Thanks,
Brandon
Old Aug 3, 2003 | 03:05 PM
Old Aug 3, 2003 | 04:13 PM
ZaneO's Avatar
Change the fuel filter first, and then check your fuel pressure to see if you are losing pressure at WOT. That would indicate a bad fuel pump.
Also check all connections on wires, opti, and coil.
edman
Mar 13, 2015 09:39 PM
DetroitZ28
Feb 13, 2015 07:33 AM
IRABuss
Sep 7, 2011 09:08 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
MislMan
Jul 19, 2002 11:41 AM
