any reason to replace water pump coupling?
I'm going to replace my water pump next week, wondering if there would be any reason to also replace the water pump coupling (connects the water pump to shaft coming out of timing cover). Can those things wear out (car has 120k)? I'm going to replace the o-rings for sure. Only reason I'm asking is the couplings are ~$35 on gmpartsdirect, seems kind of expensive.
Thanks,
Patrick
Thanks,
Patrick
Heoooo No!! I thought I lost mine when I was putting my motor back together, called the Stealership and they wanted a murderous 70 fricken bucks for that lil sonama biyatch.
I didn't even ask if they were serious. I'm still thinking they musta made a mistake.
I just replaced my water pump about two weeks ago. All I did was clean up the splines with some WD-40 and put it back in. I didn't bother to replace the o-ring on the cam drive shaft pin as the original one was stuck on. There wasn't any moisture in there, so I left it alone.
