Any performance gains to be seen?
Re: Any performance gains to be seen?
All the timing and fueling is done through the pcm, most of us trust a proffessional to do our tuning since it is VERY reasonable. They do whatevery your application calls for as far as the timing, sometimes that will mean adding more, like Brad said though the AFR is where the real power gains are to be found.
The timing runs waaaaaaay out almost on the ragged edge as it is managed by the PCM, more than 40 degrees advanced under some circumstances if I recall correctly. It is not something you will easily or safely improve on.
Originally Posted by jchevy
Even with heads and cam your timing is changed very little. Thats why a lot of guys run good times un-tuned.
Dont get me wrong, you need a tune with heads/cam. But it is still possible to run strong without one and see decent peak HP numbers. Of course the drivabilty is probably gunna be pretty crappy.
I was just saying from a timing stand point it isnt changed all that much.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
May 21, 2015 01:04 PM
May 15, 2015 10:43 AM
alex5366
Mar 27, 2015 03:30 PM
