Any new fixes for a broken ear? OUCH!
Old Jan 4, 2016 | 08:53 AM
Horrible's Avatar
I broke an ear off my harmonic balancer trying to remove it.
I saw some remedies from 2003 and just wondered if there was anything new
That someone came up with
Old Jan 4, 2016 | 10:00 AM
Re: Any new fixes for a broken ear? OUCH!
Usually, the only way that happens is by trying to remove it incorrectly. I assume you have an LT1 in some kind of car (you don't provide any vehicle info) and you actually mean you have a problem with the hub. The only "fix" is to replace it. Getting it off is going to be difficult now, since you cannot evenly distribute the force needed to pull on it. Welding the ear back on would be one solution.
The correct procedure for removal of the hub involves using a hardened rod or similar inserted (not threaded) into the crank hub bolt hole for your puller to push against.
Old Jan 4, 2016 | 11:42 AM
Heating the hub, avoiding the crank snout, may make the removal easier, as the hub expands.
Old Jan 4, 2016 | 02:39 PM
Horrible's Avatar
Yeah, I'm aware of the correct procedure, now!
Unfortunately, I followed the directions on the puller from Auto Zone rental and it says
To remove the center bolt and use their "powerbolt" instead,which I did and just as you are aware, I broke an ear off.
I have a 93 Vette and was advised to come over to this site.
Old Jan 4, 2016 | 03:26 PM
IDK what a "powerbolt" is, but something obviously went wrong.
Old Jan 4, 2016 | 06:02 PM
Horrible's Avatar
It's the threaded piece that takes the place of the center bolt.
Old Jan 5, 2016 | 11:50 AM
I'd have to see the tool and instructions to understand how that was supposed to work. You shouldn't be pushing against anything that is threaded into the hole.
Old Jan 7, 2016 | 06:55 PM
94Z28LS1toLT1's Avatar
Exactly I've taken it off plenty of times in the 9 years of having different lt1 camaros n I've never heard of this before
AdsoYo
Jul 30, 2020 08:35 PM
Hal Fisher
Jan 2, 2016 10:28 AM
gaedbo
Dec 24, 2015 08:21 AM
Red_94Formula
Mar 7, 2015 09:21 AM
1LEThumper
10
Sep 17, 2002 08:54 AM
