Any guess on Power??
Old Oct 4, 2006 | 07:21 PM
smallblockbeast's Avatar
350 LT1:
-about 10.75 compression
-Aluminum stock ported heads with competition 5 angle valve job.
-gasket match ported intake
-CC306 Cam
-1.6 Gold Race Roller Rockers
-58mm throttle body
-Moroso Cold Air Intake
-Pace Setter Long tube headers
-Off road Y Pipe
-No EGR
-No AIR
Also wondering what this car might run with 3.73 gears and a 3000 stall converter. Trans also has shift kit. 26" tall Drag Radials. Stock weight.
Old Oct 5, 2006 | 12:27 AM
CALL911's Avatar
Re: Any guess on Power??
I would say about 340 or so at the wheels, and if you can hook, then around 12.5 or so.
Thats about what I was running/putting to the ground when I had my stock heads ported and my CC306 cam with 3.73's. (I also had similar bolt ons.) Granted I am a 6-speed though.
Old Oct 5, 2006 | 05:38 AM
Joe B's Avatar
Originally Posted by smallblockbeast
350 LT1:
-CC306 Cam
-58mm throttle body
-Off road Y Pipe
-No EGR
-No AIR
Alot can hinge on how good the port work is on your heads.....who did the heads?....also, any flow numbers?..........if the heads are really top notch (Like Lloyds work)...and the tune is really good.....I'd say low 12's and mabe even some high 11's could be possible if you could get some 165ish 60 ft times......ofcourse, you would need a Top of the line 3000(or slightly higher) 2.45 or 2.5 STR stall, and the 3.73 gears......Joe
Old Oct 5, 2006 | 07:09 AM
it wasnt a crazy amount of port work. If was done by D&F down here in South Jersey.
How bad would 4.11 gears be on the highway at like 65 or so????
I was thinking like mid 12's too, so I guess I wasnt too far off.
Old Oct 5, 2006 | 07:42 AM
teke184's Avatar
2500rpms is 66mph
3000rpms is 80mph
Keenan
Jan 19, 2023 12:24 PM
warmeck
May 7, 2015 02:10 PM
dplatt3
V6 Tech
Apr 30, 2015 10:44 AM
warmeck
Feb 5, 2015 11:04 AM
XtremeLt1
Sep 13, 2002 08:50 PM
