any great install pages for removing lt1 heads
Old Aug 18, 2005 | 09:32 PM
96KillaZ's Avatar
I plan on removing my heads and getting them ported of my z28. does anyone know of any sites to help me out, thanks
Old Aug 18, 2005 | 10:48 PM
Re: any great install pages for removing lt1 heads
http://www.afrashteh.com/guide/install.htm
Old Aug 19, 2005 | 12:30 AM
blackztpi's Avatar
if nothing else follow the shoebox guide for a cam swap. obviously, skip the steps that do not follow what you're doing. (shbox.com) really though, just unbolt the intake elbow, remove the fuel rail, remove the intake bolts and remove. you will have to move the harness around but you'll get it. from there, it's just getting the heads unbolted and getting that coolant pipe off the back of each head....oh, and please do not cut it. it's really not too hard, especially if you car already has the smog crap deleted
Old Aug 19, 2005 | 12:32 AM
transamdude95's Avatar
you make it sound so simple... I would think it would be a very involved, time-consuming process... but I've never done it before.
Old Aug 19, 2005 | 12:50 AM
blackztpi's Avatar
it really is pretty simple. if you have a stock motor, its much more difficult becuase there's thick heavy manifolds in the way and all the smog pump crap hooked to the head. the intake removal is very easy, and from there, it's just removing the head bolts, coolant tube off the back of the heads, and remove the headers. the alternator and some things are also in the way, but i wouldn't expect more than about a days work to do it. doing a lifter swap, i got the intake off in an hour from start to finish. after removing the intake and all of it's junk that goes with it, it really clears up the engine bay. the wiring harness in the lt1's are not very complex under the hood. easy to move out of harms way. i have been surprised how easy it is to remove things in the lt1 engine bay. it looks very hard from even a close view.
Old Aug 19, 2005 | 01:16 AM
1FASASZ's Avatar
i did it once, and if i had to do it again i would pull the motor out. ist so hard to get to all the bolts especially if you have long tubes in your way. i had to use a swivel to get the torque wrench on some head bolts and i wouldnt trust that. probably would have saved some time to by just pulling the motor.
Old Aug 19, 2005 | 07:10 AM
dreamer1q's Avatar
I agree 100%. I can have the motor out in about 4 hours, it took me a full night to do the heads with longtubes on.
oldschool
Feb 9, 2016 09:21 PM
MadMav
Feb 6, 2015 11:02 PM
Queens94z28
Dec 20, 2014 09:11 PM
thenewkid
Nov 27, 2014 09:41 AM
Fedesna
Nov 23, 2014 11:06 AM
