Any better wires than MSD's for our cars?
Old Jan 10, 2008 | 06:09 PM
  #16
Jesse Lackman's Avatar
I got wires for the LT1 from these guys;
FireCore50.com
Old Jan 10, 2008 | 06:27 PM
  #17
MEAN LT1's Avatar
Originally Posted by truedualws6
Not sure if this helps any, but my current set is Accel 9000s and they seem
to work just fine. We will see how they hold up with the SLP shortys. I've
got the heads torqued and ordered my pushrods today with a next day
delivery (7.05") so hopefully I'll have them by noon tomorrow. I hope to be
running by late Sunday if I get the PCM on time.
Good luck with the placement of those wires with those headers. Those headers can be unforgiving sometimes. I hated them when i had them.
Old Jan 10, 2008 | 06:28 PM
  #18
billymz28's Avatar
I had the worst luck on the acell extreme 9000s they lasted about a week and 2 of them split. not burnd split so back to the trusty MSDs
Old Jan 10, 2008 | 08:11 PM
  #19
Stoopalini's Avatar
Hmm, They seem to be ok to me? Nice thing about the Accell wires, they fit in the stock looms. I ended up routing the passenger's side up through the motor mount though (so I didn't have to deal with the factory loom behind the alternator) and routed the driver's side in the factory locations.
One nice thing about the SLP shortys, you can install the plugs and wires before the headers. I just did a head gasket job, and when reinstalling everything, I put new plugs in, connected the wires, and then slid the headers in from the top. I didn't even have to remove the oil dip stick tube ..... Made it very nice!
Thomas.
Old Jan 10, 2008 | 09:59 PM
  #20
jshz28's Avatar
Originally Posted by speed_demon24
It looks like I finally found my miss. I sprayed some water on my engine bay and I got a nice lightshow out of a few wires. I'm running msd wires that are only a couple years old and they have never been burnt or anything like that. I know the taylors are prone to arcing, but supposidly msd's are better. Should I just replace them with some new MSD's? I have OVC wires so I need cut to length wires.
i would stick with the msd they have the lowest resistence which is what makes a better wire
Old Jan 10, 2008 | 10:17 PM
  #21
SS RRR's Avatar
I've used Taylor for years with no issues including the new engine.
Old Jan 11, 2008 | 02:56 AM
  #22
Fatdog2's Avatar
Previous posts have suggested that the spark is trying to find a ground,and can do this by hitting the heat shields,or anything nearby.If the wires are too close to each other,they might cause a problem.I did the accel extreem 9000 wires,and lost performance,so I couldn't afford the Magnacores,so I did the MSG's and was very happy with them(exept for the coil wire).but I didn't use the existing wire looms,so I wrapped each wire after the opti with after market spark plug boots,sliced them to fit over the wires,so as to not have each wire next to each other.(die electric greese all over the place).Maybe it's beer time now for me.
Old Jan 11, 2008 | 09:19 AM
  #23
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
I made wires for my car over the holidays. I decided to use MSD components. It seemed like more people had issues with Taylors vs. MSD. But, I didn't realize that Taylor made a 10.4 mm wire. Are those Thundervolt wires any better than their 8mm offerings?
I probably went way overboard on my wires. Considering that, I'm hoping they last quite a long time.
Is it very common for wires to arc to one another when they're in close proximity? It seems that some of the stock wire were right next to one another. Some of my wires are bunched together with tie straps. I'm hoping the insulation would prevent any arcing. I also ran heat shielding the full length of each wire.
My car seemed to run fine, but it's still on jack stands and hasn't been driven in quite a while.
mr28
Apr 20, 2016 05:44 PM
thenewkid
Nov 27, 2014 09:41 AM
USAirman93
Nov 24, 2014 03:37 PM
mr28
Nov 23, 2014 11:11 AM
supercharged94Z28
Feb 24, 2003 10:22 PM
