Antiseize Grease on O2 Sensors?
Old Aug 8, 2004 | 12:29 AM
OBE1 95Z28's Avatar
Question Antiseize Grease on O2 Sensors?
Will the grease ruin the sensor if it is applied to the threads?
Old Aug 8, 2004 | 12:43 AM
Heatmaker's Avatar
Advanced Member
Re: Antiseize Grease on O2 Sensors?
It's perfectly alright... some 02's already come prelubed with Antiseize so don't worry about it.
Old Aug 8, 2004 | 10:47 PM
OBE1 95Z28's Avatar
Thanks! Even though I heated up the exhaust system before trying to remove the old O2's, there were in there really tight.
Old Aug 10, 2004 | 04:58 PM
mzgp5x's Avatar
Only on the threads. Other wise, it will damage the o2.
Old Aug 10, 2004 | 06:12 PM
stereomandan's Avatar
The O2's come with antiseize on them. Do NOT put new antisieze on them. It says it right on the package.(ACDelco). I put antiseize(Permatex Ultracopper) on mine by mistake, but I don't recommend it.
Dan
Old Aug 10, 2004 | 07:20 PM
1 Nasty Bird's Avatar
I think you have to get "sensor-safe" antiseize, or is taht for another sensor? Pretty sure its for the O2's though.
Old Aug 11, 2004 | 09:56 AM
OBE1 95Z28's Avatar
I read the antiseize package last night and it says that it can be used on O2 sensors. I will look at the sensors and see if it was pre-applied. Mine came from GM in plastic bags (no box) so I don't remember seeing and instructions.
Old Aug 11, 2004 | 10:25 AM
The GM O2 sensors come in plastic bags, and on the back, it says that the antiseize is preapplied.
Dan
Old Aug 11, 2004 | 10:58 AM
Hyperspeed97z28's Avatar
Dan
Good info to know !
I've never used anti-seize and havent had any problems getting them off ...
Old Aug 11, 2004 | 11:46 AM
Bastardcat's Avatar
Permatex Ultra Copper is not antiseize, it is a Hi-Temp RTV Silicone Gasket Maker.
I put anitseize on the threads of my AC Delco O2's because I had a hard time removing the originals. I just don't trust that their pre-applied antiseize is sufficient. I've had zero issues with mine, so I would say do it.
Old Aug 11, 2004 | 12:46 PM
Heatmaker's Avatar
Advanced Member
I actually put Thread locker blue on my 02 sensors... No matter how hard I tightend them they always came loose.... haha not anymore
Old Aug 11, 2004 | 02:57 PM
Oh man, sorry about that. That is not what I meant to say. I did not use Permatex Ultracopper on my O2's. It was the Permatex brand antiseize that I used, in the little white tube, NOT the Ultracopper. The antiseize looks like copper flakes in a gel when you put it on.
Sorry about that. It says O2 safe on the antisieze tube, but since GM says NOT to put it on, then I don't recommend it.
Dan
Old Aug 11, 2004 | 04:28 PM
Heatmaker's Avatar
Advanced Member
knowing GM it probably says that so when it comes time to remove them they'll be stuck on so tight you'll have to take it back to them.
FredM
Aug 14, 2015 01:49 PM
350350
14
Aug 11, 2015 12:03 PM
whitehooptie
Aug 10, 2015 07:02 AM
Aug 7, 2015 01:26 PM
30th Anniv Z28
Aug 1, 2015 10:39 AM
