Antifreeze Leak?
Old Jul 4, 2007 | 09:41 PM
_94Lt1_'s Avatar
Antifreeze Leak?
I have a slow ( but noticeable ) antifreeze leak. Its coming from under the car, right before the cat-converter dripping off some hoses. What in that area could be leaking antifreeze ? And only the car is running
Old Jul 4, 2007 | 09:53 PM
Are you sure it isn't the condensate from the A/C system?
Old Jul 4, 2007 | 10:01 PM
_94Lt1_'s Avatar
bout 95% positive its not, its green, and i only ran the ac for like 5 seconds.
Old Jul 4, 2007 | 10:58 PM
The only part of the coolant system in the back of the engine would be the cross-over pipe at the back of the heads. That and the head gaskets. Then there's the hoses/connections at the firewall for the heater. And the heater core inside the airbox, with a drain hole on the bottom of the box in case it leaks.
Old Jul 5, 2007 | 03:46 PM
_94Lt1_'s Avatar
Well, i changed to a 160* Thermostat a week or so ago, and got a little antifreeze everywhere, but not back where its leaking? Unless its dribbled back there and still ther after a week ?
magman
Apr 15, 2016 03:08 AM
blac94Z
Nov 4, 2015 01:59 PM
drt
Sep 27, 2015 04:39 PM
colts0455
Sep 27, 2015 01:07 PM
Pwilson59
Sep 3, 2015 08:47 PM
