anti lock inop
Old Mar 23, 2003 | 07:20 PM
allious's Avatar
anti lock inop
what causes this light to come on? what do i check first? it just came on when i cranked it up today.
Old Mar 23, 2003 | 11:18 PM
fbird95's Avatar
It periodically comes on hear and there in some cars. It signals that the anti lock brake system will fail. Usually you can turn the car off and back it on it will turn off. Sometimes the sensors being wet can cause it. Now if it stays on or comes on frequently you have a problem with the system or the system will fail because you brakes are shot and need to get it checked out. At the current time my buddy is having a problem with his 98 cutlass, with the light staying on all the time, He got new brakes and the dealer cant seem to figure out the problem. THe antilocks still appear to work.
Old Mar 24, 2003 | 05:15 AM
badass383's Avatar
Got to have the error code. Retrieve it, reset the code to clear it and see if it returns. If it does, there is a clear diagnostic method to determine the source of the code.
Once you have seen the same code twice it's easy.
Try it.
Old Mar 24, 2003 | 12:45 PM
tom3's Avatar
burnt tail lights cause the abs inop light to come on
Old Mar 24, 2003 | 12:55 PM
93Z286Speed's Avatar
i get the same thing from time to time.. ill have my ebrake down and my brake light will stay on and my abs inop light will be on at the saem time.. only happens sometimes..
Aaront810
Aug 29, 2020 09:34 PM
colts0455
Oct 4, 2015 09:47 PM
colts0455
Sep 27, 2015 01:07 PM
Daluchman1974
Sep 11, 2015 06:12 AM
z28cam1993
Sep 9, 2015 04:08 AM
