Another WOT backfiring problem
Old May 21, 2004 | 02:34 PM
HoneyCombs's Avatar
After I rebuilt my motor, with the hotcam kit when I get on it, I get bad backfirng out of the exhaust. I put 2 new optis on, wires are pretty new, cleaned my IAC valve, throttle body is clean, and installed FRP set at 43ish at idle.
This is my "to do" list
1.Replace IAc valve totally
2.Replace TPS
3.Replace EGR vavle
4.Get heated o2's for my long tubes
5.Replace IAT
6.Readjust vavles b/c I got some clicks(would this help?)
7.?
I am stumped, is there anything else I missed. I did tons of searchs and this is what I found
Thank you very much
Matt
Old May 21, 2004 | 03:47 PM
ram air camaro's Avatar
IGNITION COIL, THAT'S A SUGGESTION
Old May 22, 2004 | 12:19 AM
my94blackz's Avatar
to what that guy said. check connections. is the opti in the right position? but as stated b4 change the 20 dolla coil.
Old May 22, 2004 | 09:50 AM
HoneyCombs's Avatar
How do I know if the opti is in the right position?
Old May 22, 2004 | 01:55 PM
CamaroSS30thAnn's Avatar
nto trying to steal the thread....but my car with the Loudmouth pops when cold sounds liek a backfire but only when u hit the gas hard when cold and let off really fast...thats just exhaust? or will coil help me ?
Old May 22, 2004 | 02:29 PM
my94blackz's Avatar
The opti has to be lined up with the cam. There is a lil notch in the opti pin that goes into your angine and on the opti it has to be matched.
Old May 26, 2004 | 12:37 AM
HoneyCombs's Avatar
Can it go in the wrong way? If it doen'st line up it wouldnt go in right?
jackpawt883
May 21, 2015 12:34 AM
Magenta_Hearts
Mar 22, 2015 03:36 PM
REDNECKISBOSS
Mar 22, 2015 08:31 AM
jayblev95
Jan 20, 2015 01:30 PM
F(ast)-body
Feb 26, 2003 09:05 AM
