Another VATS question.....should be pretty simple
Old Nov 4, 2003 | 10:55 AM
Nomar's Avatar
I just finished removing a poorly wired aftermarket alarm from my 94 Z28. I discovered the only factory wires that were actually damaged(their connector was cut off) were the 2 white wires with the orange sleeve for the VATS. The wires come from the steering column and are supposed to connect to 2 other wires.
My question is: Could I just go to a junkyard and find another GM car with VATS, go under the dash and cut this wire off, so I can splice it onto my existing wires? The chances of me finding an f-body are slim, but Im sure there will be something that has the VATS wiring intact.
Thanks,
Dave
Old Nov 7, 2003 | 04:55 AM
slopokrodrigez's Avatar
Stick a resistor across it with the same value as the chip in your ignition key. Solder it in, wrap it and be done with it. Don't reconnect it, in the end you'll be sorry.
Yes this defeats the ignition key theft device but trust me on this
Formula Steve
Sep 19, 2023 08:31 AM
walt355
Mar 16, 2016 09:35 AM
Aug 28, 2015 07:53 AM
Latronaxe
Jul 20, 2015 12:00 PM
