another trouble code
Old Jan 30, 2006 | 07:16 PM
94 guy's Avatar
i used a snapon tool and it said O2 sensor. the car runs rough at idle and up to about 3000rpm then clears up? could this be the O2? is there a way to test them?
Old Jan 30, 2006 | 08:29 PM
95nicotineZ
Guest
Posts: n/a
Re: another trouble code
If you know someone with an Ohmmeter, you can check resistance and compare it to a "good" one. That's all I can offer.
-Dave
Old Jan 31, 2006 | 06:41 AM
What was the SPECIFIC code? There are a couple different O2 sensor codes.
Can we assume from your screen name that you have a 94? Might be a good idea to add a "signature" with basic info about your car - year, tranny, major mod's, etc.
Do not put a multi-meter on an O2 sensor, unless you are sure its a very high impedance meter..... a low impedance meter can "fry" the sensor.
Old Feb 2, 2006 | 07:59 PM
94 guy's Avatar
i did'nt notice what code it was he just said it shows the o2 sensor. i get a backfire sometimes not often but the car seems to be getting worse. runs fine for say 2 minutes then just starts missing.
Cam's maro
Mar 24, 2015 08:09 PM
armedtrigger
Feb 24, 2015 08:30 PM
David Dorris
Jan 17, 2015 08:10 PM
91Bird305
Aug 5, 2002 01:39 PM
LT1
Jul 2, 2002 08:27 PM
