Another Roller Rocker question
I did a search on roller rockers and I still can not find a diffinitive answer. I want to buy some 1.6 roller rockers for my 93 LT1 Z28. Can I buy some that just bolt on in place of my stock ones. I visited a site that explained the process but it involved measuring the spring hieght and everything. Do I need to replace the stock springs? If so can I buy some that will replace without having to shim and all that? Do the roller rockers adjust like hydralic lifters setup (turn till clatter stops go another half turn)? Can I use my factory pushrods? Do they need to be measured? What else should I look at in doing this job?
You should get the springs that crane matches with the rockers this should take the guess work out of it. Yes they ajdust just like you thought turn till the clicking goes away then another half turn. Don't forget to tighten the lock nut in the top of the rocker. your factory pushrods should work fine. Mine did anyways.
Another suggestion, if you are ever planning on putting in a cam get springs that have enough lift in them so you don't have to replace them when the cam is installed.
Well that is if you order universal springs, Just buy some LT4 springs on Ebay for like 40 bucks or GMPartsdirect.com and then buy some 1.6 self aligning centerbolt valve cover rockers and you will be good to go!
Thanks for all the help guys. I have been out of GM service for about 7 years and sometimes you miss alot quickly. I am a Network Administrator for the feds now. I still do all my own work and I assembled my stock car engine for my racecar but to be honest even when I worked for the dealer most everything was R&R we would not take apart a head to replace a valve or rebuild a motor. We would just put in a new one.
Originally posted by race24x
I noticed some others talking about measuring spring hieght what is this for???
You will probably select springs that are much better than stock and therefore overkill for the stock cam so its not nearly important to measure installed height with the mild stock cam. Your heads are also stock and weren't machined for larger spring pockets or anything trick like that which would require you to double check the machined dimensions came out correctly.
-brent
oldschool
Feb 9, 2016 09:21 PM
