Another question on installing the head bolts...need answer ASAP!
Old Apr 9, 2003 | 04:12 PM
94 CAMRO Z28's Avatar
Question Another question on installing the head bolts...need answer ASAP!
The ARP instructions say that if they bolts go into a water jacket to use thread sealer, and if they go into a blind hole use a moly lubricant. All of the stock bolts that came out appear to have thread sealer on them. So should I just seal all of them or not? If not which ones should I not use the sealant on? Also, for tq. them it says to tq. to 65lbs if using a moly lube or to 85 if using 30W motor oil as a lube. It then says due to expansion of aluminum to only tq. to 60lbs. So what should I do here? Thanks
Aaron
Old Apr 9, 2003 | 04:29 PM
Ok I re-read the directions and it specifically says for aluminum tq. them to 60lbs if your using moly lube or sealer. So I guess the only question is do I use sealer on all of them like the stock bolts? Or not?
Aaron
Old Apr 9, 2003 | 07:35 PM
Mtrhds94Z's Avatar
Sealer on all..
Old Apr 9, 2003 | 09:22 PM
WP's Avatar
WP
sealer on all,torque to factory specs.~65ftlbs.
Old Apr 9, 2003 | 09:25 PM
Rodrigues's Avatar
I dipped them all in 30wt oil, then put a little sealer arround the bolt and bolted them in at 65 ft lbs.
Old Apr 10, 2003 | 04:21 AM
Mtrhds94Z's Avatar
Needless to say torque it in steps also..
Old Apr 10, 2003 | 07:53 AM
Just curious, how does sealer stay on the bolt after it is dipped in oil?
Old Apr 10, 2003 | 08:12 AM
Don 97 SS's Avatar
Hee hee That was funny.
I just use RTV sealant on all of them.
Old Apr 10, 2003 | 08:23 AM
IRABuss's Avatar
that makes for a nice mess when changing heads...RTV would be the last thing i use. there is a special ARP sealant you use, or you can get the same stuff from the dealer for 10 dollars more...
Old Apr 10, 2003 | 08:42 AM
Don 97 SS's Avatar
IRABuss, this approach has worked for me without much mess. I recently did a BBC engine with alum heads this way. Also, several performance engine builders around Raleigh area do the same. That is were I picked up the idea. I would agree that ARP makes great products and I'm certain that they work well. It is just that there are other ways to skin a cat.
Old Apr 10, 2003 | 10:49 AM
Rodrigues's Avatar
I tried it and it stayed on fine...
Old Apr 10, 2003 | 11:04 AM
JBirdSS's Avatar
Cat skinning process:
1. Operation success
2. Patient died
Noenav
Mar 1, 2019 07:38 AM
oldschool
Feb 9, 2016 09:21 PM
mikey4play
Mar 15, 2015 11:45 AM
ro2207
Dec 4, 2014 06:18 PM
Brent94Z
Mar 21, 2002 04:44 PM
