Another Opti ??? Please Help
Old Oct 24, 2003 | 12:28 PM
DB75's Avatar
I have a '94Z. I want to change to the '95 vented setup. I know all about the parts and part numbers to make the swap. What I don't know is if I have to change my waterpump. Will the '95 conversion work with my '94 pump or do I have to get a '95 + waterpump?
Old Oct 24, 2003 | 12:54 PM
If you go with a stock type cam gear, you can use your stock water pump. Only if you go with an older SBC timing set, will you need to change the pump.
Old Oct 24, 2003 | 01:05 PM
DB75's Avatar
Shoebox, I was thinking about getting the hotcam kit also. Is that cam considered a stock type cam? And is it worth upgrading to LT4 timing set? I think it's kinda of pricey but I have 74,000 miles on my car and I'm not sure if I should replace it w/the stock timing set or the LT4. Thanks for the quick response.
Old Oct 24, 2003 | 01:15 PM
If you plan on lots of high rpm running, the LT4 timing set is good insurance. When I said "stock type", I was referring to the gear, not the cam, but that cam is fine.
Old Oct 24, 2003 | 01:18 PM
DB75's Avatar
Sorry, I realized I read it wrong after the fact. Thanks again.
Old Oct 24, 2003 | 01:57 PM
Z28tech's Avatar
Hellion
There are three variations of the LT1 out there. I will have to research and figure out what your timing cover looks like. Big hole or little hole. 94 and 95 are probably the same from what I remember. 93 had big hole cover and 94-95 had small hole with remodeled water pump/
Formula Steve
Sep 19, 2023 08:31 AM
94Maroz28
Oct 27, 2015 04:38 PM
Ks0209
Oct 1, 2015 07:32 AM
colts0455
Sep 27, 2015 01:07 PM
jayblev95
Sep 26, 2015 09:44 PM
