another oil leak thread, I used dye now need advice
Old May 12, 2009 | 11:00 PM
apyah's Avatar
1997 camaro z28, getting oil on the front of the engine thought it was a crank seal but it has to be higher. I used that uv die today and still cant pinpoint it but ruled out crank seal. I see oil dripping from the passenger side bottom bolt of the opti. it is running from somewhere down to there. perhaps water pump shaft or opti. guess I have to do them both. is there anything I may have missed and are both seals pretty easy to do. thank you in advance. Allen
Old May 12, 2009 | 11:03 PM
Stl94LT1's Avatar
http://www.impalasuperstore.com/nais...84&whichpage=1
Old May 13, 2009 | 06:46 AM
bw_hunter's Avatar
The seals are both easy to replace. Also replace the crank seal while you're in there.
You'll need to remove the water pump, opti, harmonic damper, crank hub, and timing cover to replace them...that's not exactly hard but it's a bit of work. Popping the seals in and out is the easy part.
Old May 13, 2009 | 06:50 AM
DAVE00's Avatar
Probably your WP seal as this is the most common one to leak. My suggestion is since you are down there and have to pull alot go ahead and do them all at once and save yourself the trouble down the road. When installing the WP seal make sure to get it right or you'll tear it and have to start all over again. Here is a cheap tool that will help you get it right:
http://www.ls1tech.com/forums/non-ls...eal-tools.html
Good luck!!!
Old May 25, 2009 | 12:49 AM
apyah's Avatar
seals replaced no leaks
replaced the seals and no more leaks, tool I bought from a link sent to me works great. thank you for all the advice, now on to the fuel pump.
Magenta_Hearts
Mar 29, 2017 08:54 PM
Brake_L8
Jan 20, 2015 09:44 AM
artic94
Jan 17, 2015 11:19 AM
96z
Sep 5, 2002 07:53 PM
Dr. Weir
Aug 2, 2002 02:36 AM
