Another engine noise question
Old May 4, 2004 | 02:14 PM
IBLUEBY's Avatar
I have searched the "engine noise" threads for about an hour and can't find anything similar to what I am experiencing.
I have the normal clicking and ticking that I would expect from a 130,000 mile car. Lord knows the car could use a few upgrades like cam, rr's, lifters, pushrods, springs, aw hell - I need a new engine, O.K!?
At any rate, over the past 2 days my little oil covered 96 LT1 has developed an odd sound that seems to be originating under the valve covers (yes, I seem to hear it on both sides of the engine). It is not quite a "squeak" but more of a "chirp...chirp...........chirp...............chirp ..chirp. It doesn't seem to have any rhyme or steady pattern to it.
It is a somewhat muffled noise and I have not tried taking the belt off to see if it stops because like I said it doesn't seem to be coming from that far forward. I just wanted to know if anyone has run into this kind of thing before I start taking stuff apart and turning bolts.
Thanks in advance and sorry for the lame description!
Old May 4, 2004 | 04:25 PM
S.J.S.'s Avatar
I had that same exact noise and it ended up to be.... well I believe it was a header bolt. Don't ask me how but it was. Dunno if it is the one by the alternator, but it definately was that. Hope this helps.
Old May 4, 2004 | 05:30 PM
generic's Avatar
I had the same noise on my 96 Caprice, it had about 120k on a supercharged LT1, it went away by itself after about 2 oil changes.... Sorry I cant tell you exactly what it was :-(
Old May 5, 2004 | 08:56 PM
IBLUEBY's Avatar
Thanks for the responses! I don't have headers but it does sound like something loose. Since there is no pattern to the noise I keep thinking it is something vibrating and rubbing together.
Maybe it will go ahead and fall off soon!
Any other ideas?
cmdeshon
Dec 27, 2014 10:06 AM
ro2207
Dec 4, 2014 06:18 PM
squarehead
Nov 21, 2014 08:02 PM
Omega9
Aug 2, 2002 12:33 AM
squirrels
Jul 13, 2002 01:58 AM
