Another EGR question
Old Jun 21, 2004 | 02:39 PM
94NDTA's Avatar
If I plug off the EGR vacuum line, do I still need to block off the EGR exhaust gas tube?
Old Jun 21, 2004 | 03:07 PM
What are you trying to accomplish? Did you get headers without an EGR connection? Just trying to clean up the engine bay? Assuming there is some sort of performance gain?
Old Jun 21, 2004 | 03:28 PM
disco192's Avatar
If you have a faulty EGR, it will still leak after you plug the vacuum line. To totally do away with the EGR, you can jusy pull the EGR off the manifold and make a gasket to block off the top port. I used 3 layers of Dr Pepper cans and it works great.
After that, you can plug up the line at the headers and take out the tube that goes into the manifold. You dont need to plug that hole, as long as you plugged up the EGR well.
Old Jun 21, 2004 | 04:16 PM
94NDTA's Avatar
I'm sorry, I am done with my header install, and am still confused on what to do with my EGR. I was told by one person If my EGR works fine, I would just need to plug off the vaccum feed. I was wondering if there would be anything else to do.
Old Jun 21, 2004 | 04:27 PM
valter's Avatar
Plugging intake hole mandatory and will let you avoid vacuum leak. If you leave EGR solenoid vac line unplugged/opened EGR membrane will never open, so it's somehow fine. But EGR will give you trouble code anyway (I am not sure on '94), since signal to open EGR will not result in voltage change from MAP. Cleaner way - remove all EGR stuff, there is a lot of info on this board on it...
Old Jun 21, 2004 | 04:59 PM
You still haven't answered the question... WHY are you deleting it? What you are trying to accomplish will dictate what you need to do.
Old Jun 21, 2004 | 05:28 PM
94NDTA's Avatar
I am getting rid of it because I didn't know whether or not I could keep it after my non-emission header install. If I can just leave it all there without a problem (after the exhaust tube has been disconnected) it would be nice. Does that help....or do you need any further information?
Old Jun 21, 2004 | 05:35 PM
disco192's Avatar
http://shbox.com/1/egr1.jpg
Ok, so you can plug up the EGR valve by removing it (1/2 open box wrench) and cutting out a gasket of some kind to plug up the holes.
Once you get the EGR valve plugged, then you can leave the vacuum line on it because even if it opens then the exhaust gas will be blocked by the plate.
Then if you have Off road headers (no EGR fittings) then you can remove the EGR exhaust gas feed pipe. You dont need to block off this hole because it just goes straight to the EGR valve through the intake (doesnt go into the plenum).
Hope this helps.
-Stu
Noenav
Mar 1, 2019 07:38 AM
edman
Mar 13, 2015 09:39 PM
97SSdude
Dec 31, 2014 07:43 PM
cmdeshon
Dec 27, 2014 10:06 AM
thenewkid
Nov 18, 2014 12:57 PM
