Another Bad Day At The Track! Help Please!!!
Old Jul 23, 2010 | 10:30 PM
pboxfun's Avatar
Exclamation Another Bad Day At The Track! Help Please!!!
Well I finally went back to the track thinking my problems were solved. My car was shifting hard and quick, I just put a new stall in, and there was no more high rpm backfiring. But I guess there is still a problem. All my mods are in my signature.
This was my best slip of the night
R/T .175
60' 2.028
330 5.912
1/8 9.140
MPH 76.08
1000 11.930
1/4 14.286
MPH 95.82
The car felt like it had no *****! It would launch hard but take forever to speed up! I felt like it was just sitting still. Anyone have any idea what could cause this?? Could it be a fuel or compression problem? IDK what to do now. Any help would be great!
__________________
94 Camaro Z28 A4 with 3200 Stall, 3.90, Headers, Borla cat-back, cc503, 1.6rr, 52mm tb, 24#SVO Injectors, SLP CAI, Mad Z28 Tune, AIR! EGR! Hoosier DRs, Aluminum DS, Strut Bar, SFC, and all other bolt-ons and free mods you can think of!!!
Old Jul 24, 2010 | 12:27 AM
razor02097's Avatar
when did you get your tune done?
Any SES light?
Old Jul 24, 2010 | 04:48 AM
pboxfun's Avatar
No SES lights. But I got the tune done about a month ago when i finished putting my cam in.
Old Jul 24, 2010 | 06:26 AM
What was the temperature, humidity, barometer? What is the elevation of the track?
Old Jul 24, 2010 | 03:19 PM
pboxfun's Avatar
I go to MIR in Maryland. So its just about at sea level. It was prbly in the 80s and humid. Can anyone else think of anything?
Old Jul 24, 2010 | 04:49 PM
NJ-LE's Avatar
pboxfun:
Could the PCM have been retarding the timing severely because of noisy rockers or a bad tank of gas? Have you recorded a poor pass with Freescan or Datamaster to check for retard?
Old Jul 24, 2010 | 10:15 PM
pboxfun's Avatar
No i haven't yet I'm in the process of figuring out what i need to get to be able to datalog my car. I was wondering tho..what if i un hook my knock module from the block? Could this be a quick fix? till i can fix it? Or will it not work at all?
Old Jul 25, 2010 | 12:36 AM
Bersaglieri's Avatar
Don't unplug the knock sensor, that won't help ya. Take the time and check for burnt sensor wires, leaking headers and all the other small stuff. I took my motor apart and found 5-6 different reasons I was having problems at the track. Broken weld on the headers, burnt knock sensor wire, burnt 02 sensor wires, etc.
-Dustin-
Old Jul 25, 2010 | 01:04 AM
Temp and humidity have been been extremely high recently. You have to correct for the ambient conditions.
Unplugging the knock sensor (the knock module is not in the block, its in the PCM) will cause the PCM to constantly retard spark timing, up to 15 degrees, based on engine operating parameters. It will only make it slower.
Old Jul 25, 2010 | 10:00 AM
pboxfun's Avatar
Ok so im def not going to unplug that then.lol Where do you guys recommend me getting everything to datalog my car from?
Old Jul 25, 2010 | 10:14 AM
Free software:
TTS DataMaster (free download, 20 free uses before license required):
http://www.ttspowersystems.com/
FreeScan (free):
http://andywhittaker.com/ECU/FreeSca...0/Default.aspx
Purchase software:
EFILive V4
Cable:
http://www.akmcables.com/
How to read the data:
http://www.injuneer.com/ScanMast.html
Old Jul 27, 2010 | 08:51 AM
pboxfun's Avatar
Thanks I just ordered everything so hopefully it'll come in soon.
Old Jul 27, 2010 | 08:57 AM
JakeRobb's Avatar
Super Moderator
While you wait for it all to show up, I'm going to guess that if you unplug the knock sensor and it doesn't get even worse, then you'll know a bit more about the problem.
Old Jul 27, 2010 | 09:08 AM
pboxfun's Avatar
haha Yea that could be one thing I could do. I think i'll try and get a fuel pressure reading. When I datalog the car what will it tell me about my fuel? or does it only tell me about my injectors
Old Jul 27, 2010 | 09:14 AM
There is no feedback to the PCM regarding fuel pressure. All you will see that is fuel related is the injector pulse widths, the long term and short term fuel corrections and the injector duty cycle (DataMaster, and its sometimes "off").
