Another 383 build ?'s thread..
Old Jul 22, 2009 | 03:20 AM
511ERT's Avatar
Ok, here is my thing. I am currently gathering parts and $ for my 383 build. This will NOT be a daily driver but it will see about about 70% street time, mostly weekends and for driving to car shows (not entering them) I am not concerned at all about gas mileage but I am concerned about reliability, and longevity. This will not be an all out drag engine, but I want to be able to make a 400 mile round trip without anything disasterous happening and I don't want to have to rebuild it after 10,000 miles. So basically what I am wanting to know is, are there any things in particular I should be looking out for with tolerances, and parts choices.
(A little more info for ya) The heads will be getting fully ported (and no I will not mention by which place either, lol) and I will get a forged rotating assembly. The machine shop will be doing the machine work on it but will not be building it though. I have plenty of experience rebuilding stock engines, just not with higher hp applications, so any help would be appreciated !
PS. I don't want this thread going towards the trans or rear end either, I have those figured out.
Old Jul 22, 2009 | 04:58 AM
rskrause's Avatar
Moderator
Al else being equal, the thing that kills engines is detonation. With a race engine, rpm plays a big role as well, but that shouldn't be an issue with what you are building. So, don't go wild on the CR and concentrate on mid range power, not top end in your choice of cam, heads, etc. Other than that, use good quality parts, and assemble them carefully and you should be fine.
Rich
Old Jul 22, 2009 | 11:56 PM
511ERT's Avatar
Thumbs up
Thank you very much for the info ! I was hoping that I would get a response from you on this.
Thanks again.......
511ERT
Old Jul 23, 2009 | 08:24 AM
rskrause's Avatar
Moderator
In terms of specific parts, if you go with an inexpensive offshore rotating assembly Scat is a much better choice than Eagle for the crank. Callies Compstar is the premier offshore brand. The cranks are very nice but pretty pricey. The rods, complete with ARP 2000 bolts are not much more $$$ than the Scat or Eagle and much nicer. Manley has a decent piston and you can often fine them pretty cheap on eBay, for some reason.
Remember, the power is in the heads/cam and valvetrain.
Rich
pepon214tx
Sep 20, 2015 04:48 PM
Z Power
Sep 19, 2015 11:19 PM
cristian1311
Sep 12, 2015 08:16 PM
95craz28
11
Sep 12, 2015 07:47 AM
sleeperZ96BT
Sep 10, 2015 08:01 AM
