another 383
Old Aug 15, 2007 | 08:59 AM
  #16
pizzi-man's Avatar
I got a part number for valve covers from Don @ fuel injections specialitys Wysco Part # wa6034 so with that no problem with clearance.
Old Aug 15, 2007 | 02:26 PM
  #17
mpayne's Avatar
Originally Posted by 96capricemgr
But how does it perform?
I see a LOT of guys pushing the XFI stuff and I see a lot of disappointing results from the XFI stuff. People mistake latest for greatest.
How high are you willing to rev?
I don't know how it will perform, the only xfi cam setup I've seen results from is a thirdgen from this board. 350 hp or so to the wheels with a 3000-3500 stall with the xfi 268. I'd say thats pretty good for 218/224 duration. The xfi cams have steep ramps so the rest of the valvetrain has to be able to handle it to get the most out of it.
What setups have you seen or heard about that were disappointing?
I'm going to rev mine a little past peak power at the strip, which I'm guessing might be around 6200-6300 rpm. I trust my bottom end and valvetrain to just under 7000 rpms.
Old Aug 15, 2007 | 02:33 PM
  #18
Purplemaroz28's Avatar
i dd my 383 w/ and le1 350ci cam, passes smog so easily, and has gobs of torque, but im looking to upgrade to a bigger cam, and i highly suggest you do the same to get the full potential of your motor.
  #19
mpayne's Avatar
Originally Posted by blackz97
peak intake flow with those heads is achieved at .550 lift with no change at .600 according to afr's website. So no need for a cam with huge lift.
Steve
Even though the xfi cam I recommended has .576 lift and the heads don't flow anymore air from .550 to .600 lift, the added lift means the valve is coming off the seat faster, so the cylinder starts filling earlier, that combined with good mid lift flow numbers could mean more midrange torque.
Z Power
Sep 19, 2015 11:19 PM
cristian1311
Sep 12, 2015 08:16 PM
95craz28
11
Sep 12, 2015 07:47 AM
smoknta
Aug 27, 2015 05:07 PM
alphaauto
Jul 26, 2015 04:40 PM
