Annoying Rattle
Old Aug 13, 2003 | 03:30 PM
Will84's Avatar
Annoying Rattle
I've got a terrrible rattle coming from the rear, passenger side of my car. I can't figure out what it is. It sounds like the Lower Control Arm is lose (if you've ever had that problem)... but it's not.
It's not the Lower Control Arm, Shock, Spare Tire and Jack, or the Speaker next to rear, pass. seat (sounds like its coming from that area). I've checked everything on the interior. I don't know what else to check.
Any suggestions?
Old Aug 13, 2003 | 05:30 PM
RKB4C's Avatar
We had a similar noise (95 A4 T/A) - turned out to be worn tranny mount. We heard sound when making turns, got progressivey worse until we had it changed out.
Old Aug 13, 2003 | 05:57 PM
Camaro_Maniac63's Avatar
I have a similar rattle, and it turned out to be the strut that holds the hatch open. I made a friend sit in the back seat and hold the strut and the rattle went away while he was holding it...
Old Aug 25, 2003 | 10:54 AM
villageidiot33's Avatar
Check Motor mounts
I had the same sound coming from passenger side. I checked heat shield,shock mounts and nothing. I jacked teh car up and started to hit the exhaust pipe and traced the sound to a motor mount. Had a metal vibrating sound in the actual mount. I tightened it and sound was gone. Just worked lose from engine vibrations I guess.
Old Aug 25, 2003 | 11:04 AM
Will84's Avatar
Thanks guys.
I figured out what it was. I said before that it wasn't the lower control arm.... well, it was.
I guess when I looked under the car, I just looked at the bolts to see if they had backed off. They were fine. I could have sworn that I grabbed the LCA and shook it to see if it rattled.. I guess I didn't. It's not the bolt though, it's the bushing. The front bushing has "wallowed" it's self out. I guess that's what I get for buying cheap-*** parts from Lakewood. I have only had them for about a year.
I always have a problem with the pass. side LCA. It's always coming loose. It's always the rear bolt, but this time it was the front.
Thanks again.
autoxr166
Sep 25, 2015 04:21 PM
cristian1311
Sep 12, 2015 08:16 PM
Boss002
Jul 24, 2015 10:47 AM
jayblev95
Dec 1, 2014 06:55 AM
squarehead
Nov 21, 2014 08:02 PM
