Anitfreeze in cylinder??
Old May 27, 2004 | 08:39 AM
TN94Z's Avatar
When I removed the driver's side head there was some antifreeze that leaked into the cylinder and is sitting in there on the piston. Will this hurt anything? I am gonna soak it up with a rag to get it out but is there anything I should worry about? There is not alot just a little puddle. Also the pistons are caked with soot or carbon build up maybe..is this gonna hurt anything? I haven't checked the cylinders yet for ring grooves etc..
Old May 27, 2004 | 09:07 AM
If you did not drain the block, it is common for a little coolant to get in the cylinders when you pull the heads. Just soak it up.
Old May 27, 2004 | 09:39 AM
TN94Z's Avatar
Cool...I drained the pass. side but couldn't get the plug out of the driver's side. I'll soak it up and forget about it. Thanks.
G-BODYT56
Jan 14, 2022 11:14 PM
94Maroz28
Oct 27, 2015 04:38 PM
jayblev95
Sep 26, 2015 09:44 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
