Am I set to install my heads?
Old Sep 15, 2007 | 09:54 AM
95z28man's Avatar
Here's my current parts list about to be ordered for my LE2 h/c.
-ARP hex head cylinder bolts
-Crane 1.6 NSA full roller rockers
-Crane 7/16" studs
-LS7 lifters
-Trickflow guideplates
-Pushrod length checker (I have hardened rods that I'm hoping will fit)
-GM LT1 head/cam swap gasket package
Anything else I should look into? Any changes you guys might recommend?
Thanks a lot
Old Sep 15, 2007 | 11:32 AM
truedualws6's Avatar
Here is a post I put up a couple of weeks ago:
http://web.camaross.com/forums/showthread.php?t=541777
Just be sure the GM gasket set has the EGR and air bleed gaskets. Also,
it's a good idea to replace the air bleed bolts. I did a search on this and
the GM replacement bolts are supposed to be better than the originals.
You will know for sure once you remove them.
I've also changed some valvetrain hardware and went with Crane steel
retainers and locks (99936, 99097).
Old Sep 16, 2007 | 08:57 AM
95z28man's Avatar
Good thread, looks like I can use that to get all my parts as well. Thanks
HectorM52
Jul 30, 2017 11:46 AM
parkers Z28
Mar 11, 2016 08:14 PM
MadMav
Feb 6, 2015 11:02 PM
F(ast)-body
Feb 26, 2003 09:05 AM
