Am I running too lean!??
Old May 1, 2006 | 02:54 PM
93redBirdMan's Avatar
Here is the Air Fuel Ratio I got from the dyno I did the other day. I've been reading around about AFR and just wanna know if I am running too lean...
http://putfile.com/pic.php?pic=4/11818554625.jpg&s=x402
Old May 1, 2006 | 02:58 PM
CustomSSI's Avatar
Re: Am I running too lean!??
Well first off where was the wideband located in your exhaust? Your a bit lean but you may want to have a bung welded in closer to your manifolds (beginning of Y-Pipe) to get the most accurate reading....
Old May 1, 2006 | 02:59 PM
Alvin@pcmforless.com's Avatar
That doesn't look to bad at all. anything over 13.30 is a bit higher than ideal but I don't start to cringe until I see 13.40's across the board. You will likely loose a touch of power by going any richer.
Old May 1, 2006 | 03:04 PM
Thanks for the input Alvin. I soon will be swapping out my Granatelli MAF for a stock MAF. I wonder how this will affect my car with the tune on it and all...
grabbem88
Feb 13, 2015 03:09 PM
Iamherefornow
Jan 26, 2015 04:57 PM
Amshnock
14
Jan 18, 2015 11:47 AM
TechCam97
Sep 12, 2002 07:20 PM
