Am I down on power?
Your typical M6 full bolt-on car is going to be somewhere around ~295 rwhp with LT's, cold air, a bolt on tune, etc through a 10 bolt.
Your best bet is to estimate the loss % from going to a 9" from a 10 bolt and go from there.
FWIW, back in the day with bolt-ons and a 2800 stall my car put down 272 rwhp untuned through the 10 bolt.
I'd say you're slightly down on power, but nothing too extreme. The 9" on the bolt on car is definitely hurting you at this point, but at least you're set for future power upgrades.
You really need a tune even on a stock LT1, and that rear is way overkill for your mild setup. 9" is way too much drivetrain loss for a CAI/exhaust LT1 - that is probably why your numbers havent changed much.
Of course you should datalog to check for things like false knock and running rich(which you probably are since the exhaust leak), but nothing is probably wrong with your car.
A bit off topic, but a 12 bolt is not an easy rear end to break. I cannot think of three people I know who have broken them myself...Were they on adjustable suspension components and self installed gears? Sounds like user error to me. Bad pinion angle or not properly meshed gears will grenade a rear in no time -much more likely IMO. Of course everyones experiences will vary, and autos are a lot more gentle then a stick, but I have ran 11's on my 10 bolt(knock on wood). A 12 bolt upgrade will be in my future, but I see no need for a 9" on a street/strip LT1.
**edit*** For reference my Z barely touched 265 to the wheels when it had all the bolt-ons(except for EWP) through a 3k fuddle and a 10-bolt. That is also including things people miss like 1.6rr's, ignition, tune, etc. I can't believe how many people get(or claim) 300+ to the wheels with just headers/cai/exhaust - but I am not there so what do I know *shrug*. That modest rwhp ran consistant 12.8's all day though
**edit**
**edit**
id change out your o2 sensors and do wires..eliminate the simple things first. and a good dyno tune will really help out your engine. im in a similar situation as you tho,.. no local places to do em
Just under 300RWHP and that was before RR's, Headers and Exhaust, and it might have been over 300 if the dyno operator actually spun the car up over 160 (had 2.73's at the time)...
9 inch will eat alot more hp than your 10 bolt did.
A LT/ORY install doesn't need to be tuned to see a significant gain.
So I've read. Regardless and as stated before it still doesn't need to be tuned to see a good gain. Personally I don't believe in 10rwhp gains. Reason being a gain/loss can happen simply from heat soak/coolant variance from the same dyno session.
Back in my bolt-on days I gained a consistent mph out of a bolt on tune in same conditions.
What's significant to you? For the price of a mail order tune, that's some pretty cheap HP. Not to many other ways to pick up 5-10 HP for that kind of money that I know of. But hey, I'm all ears.
I went from going 110mph to 114mph simply going from Edelbrock shorties w/ stock y-pipe (cats included) to LT's and ORY with no tune to accommodate the LT's. I think that's pretty significant. As stated I really don't believe in noting 5 or 10rwhp gains. Way too many variables come into play.
And one last thought. Maybe your tune was off a little, and benefited from the header swap. Free updated tune? Thats pretty cool.
