Aluminum heads?
Old Oct 28, 2005 | 02:04 PM
  #16
96capricemgr's Avatar
Re: Aluminum heads?
Originally Posted by Mindgame
You don't convert people to catholicism in your spare time do ya Dwayne?
Stock flow iron vs aluminum.... who really cares? If you never plan to have the heads ported or bump the compression then just stay with iron. Otherwise I'd step up to aluminum.
My 2 centavos.
-Mindgame
I would never recommend anyone swap either stock for stock I know someone who bolted 96 Vette heads on a Caprice before he found the internet and he found out firsthand that even the best flowing stock aluminums were a waste of effort on an iron head car. Just took that guy for a ride in my mildly cammed stalled geared car yesterday think I impressed him when she broke the rear loose at 30mph roll with 255/50/17s outback.
As I said I am not saying everyone should swap to them and am actually going to go to aluminums myself just really hate the misinformation that gets spread about the irons. As for catholicism I was baptized such but am now a confirmed atheist .
I am off to GLD to set a new PB wish me luck.
Old Oct 28, 2005 | 02:49 PM
  #17
breakmyfootoff's Avatar
Re: Aluminum heads?
Originally Posted by 93turbo5oh
with 17 head bolts per bank you are doing something really wrong if you are blowing HGs with aluminum heads. ive run 18lbs of boost on a ford 302 (10 head bolts per bank) with gt40 aluminums (not the thickest decks in the world) making 550rwhp and never had a problem. so i dont know what you guys are doing.
Just because it didn't happen to you doesn't mean the problem does not exist, people blow head gakets all the time, I wanted to decrease the odds as much as possible.
Old Oct 28, 2005 | 04:23 PM
  #18
93turbo5oh's Avatar
Re: Aluminum heads?
you just made it sound like it was a problem you were having. back in the late 90s at AMS we built several poweradder lt1s with aluminum heads, several above 650rwhp. and never had a problem with HGs. i dont know how people are blowing them NA.
Old Oct 28, 2005 | 08:28 PM
  #19
1996LT1NY's Avatar
Re: Aluminum heads?
Originally Posted by 96capricemgr
And those lowly iron head flow more than the 95 aluminums
Gee... I didnt know that was comming
Old Oct 28, 2005 | 09:23 PM
  #20
marshall93z's Avatar
Re: Aluminum heads?
I have had mine overheat and peg the gauge probably 20 times MINIMUM, and never a blown gasket or a warped head!!
Old Oct 28, 2005 | 09:51 PM
  #21
93turbo5oh's Avatar
Re: Aluminum heads?
there's something to brag about.
Old Oct 28, 2005 | 10:09 PM
  #22
Re: Aluminum heads?
Not bragging about the ignorance of overheating it, or anything.....just saying they are tougher than people think.
Seems like My hoses always leak when there is NO water around!
Old Oct 28, 2005 | 10:49 PM
  #23
Re: Aluminum heads?
What kind of combustion pressures do you think your engine is producing, how much boost are you running?
Old Oct 29, 2005 | 12:23 PM
  #24
Re: Aluminum heads?
You see it come up every so often I think it has more to do with age than power with probably a little neglect of one sort or another thrown in. I would not call it common by any means but have actually seen f-body blown gaskets on stock motor. The expansion rate difference might even be the culprit just takes YEARS of it to cause an issue on a few cars.
Last night I went 13.2 at 101.3 I don't think that too bad for 4300lbs with my "baby" cam and crappy stock iron heads, got about 23mpg on the 2.5 hour each way trip and that includes the racing.3.42s are good for that but she needs more gear at the track.
*Emilia*
May 13, 2015 09:05 AM
cmyname1
Feb 19, 2015 08:38 PM
InfernalVortex
Jan 17, 2015 09:35 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Brandon Wittmer
Dec 7, 2014 12:15 PM
